29487 Discussions
problem with libstdc++.so.5 using intel fortran compiler 11.0
jstaubin
I have installed the intel fortran compiler on my system (Linux redhat 3.4.3) with only one error message where the installation could not recognize the operating system. Other than that, the installation went fine. I have added the line
"source /bin/ifortvars.sh intel64"
to the .bashrc file as required. When trying to use the fortran compiler, I get the error:
/bin/intel64/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
Now, the problem is that I DO have the compatibility standard C++ library compat-libstdc++ installed and the 'missing' libstdc++.so.5 file is in /usr/lib/libstdc++.so.5 where it should be. There was no error about this during the install which to me means that the install found the libstdc++.so.5 file. How come it doesn't find it now? I'd appreciate any help at all. Thanks.
Kevin_D_Intel
The Intel 64 compiler in the 11.0 release is a native 64-bit executable and requires /usr/lib64/libstdc++.so.5 andnot the 32-bit version you indicate finding on your system.
Does the Intel 64 compiler work if you source ifortvars.sh directory under the working shell?
Could you share the uname a output from your system also?
Kevin_D_Intel
jstaubin
Thank you for your response. I cannot use the compiler even if I source the ifortvars.sh directory in the working shell. You are also correct that I do not have a libstdc++.so.5 file in my lib64 directory (which is most likely the problem). I am working at finding the correct 64 bit version of compat-libstdc++ for Linux Redhat 4 - do you know where to find it?
also:
uname -a
Linux mpclus06 2.6.9-42.0.2.EL #1 Wed Aug 23 13:03:03 BST 2006 x86_64 x86_64 x86_64 GNU/Linux
Thanks again for your help
Kevin_D_Intel
Sounds like you installed the i386 compat-libstdc++. You need the x86_64. Probably best to check with Red Hat first.
On our Red Hat EL 4.3 system, the required versions originates from the following RPM package:
$ rpm -q -filesbypkg compat-libstdc++-33-3.2.3-47.3
compat-libstdc++-33 /usr/lib/libstdc++.so.5
compat-libstdc++-33 /usr/lib/libstdc++.so.5.0.7
compat-libstdc++-33 /usr/lib64/libstdc++.so.5
compat-libstdc++-33 /usr/lib64/libstdc++.so.5.0.7
The rpm version at the URL below may work for you, but again, check with Red Hat too:
http://rpm.pbone.net/index.php3/stat/4/idpl/1824545/com/compat-libstdc++-33-3.2.3-47.3.x86_64.rpm.html
TimP
You would get this libstdc++ and a bunch of other stuff you need by installing the (64-bit)gcc-c++ development option, either in Add/Remove Software or in the original installation.
