problem with openmp hello world!
farzin_p_
Dear all,
I have some problems in compiling the following prototype. I execute the attached simple program using multiple cores. Problem is that I am all the time getting just one instead of multiple 'Hello World's.I have used -openmp -Qparallel -fpp settings.
Thanks in advance.
John_Campbell
New Contributor II
try something like:
[fortran]program main
implicit none
integer*4 omp_get_thread_num
integer*4 i
write ( *, * ) 'A sequential hello to you!'
!$omp parallel do
do i = 1,15
  write ( *, * ) ' Parallel hello''s to you!', i, omp_get_thread_num ()
end do
!$omp end parallel do
stop
end[/fortran]
farzin_p_
Dear John,
 I tried your code. But as can br seen, just 'thread 0' is working. what about the other threads? I'm using an intel  core i5-2400 CPU.
thanks.
  Parallel hello's to you!           1           0
  Parallel hello's to you!           2           0
  Parallel hello's to you!           3           0
  Parallel hello's to you!           4           0
  Parallel hello's to you!           5           0
  Parallel hello's to you!           6           0
  Parallel hello's to you!           7           0
  Parallel hello's to you!           8           0
  Parallel hello's to you!           9           0
  Parallel hello's to you!          10           0
  Parallel hello's to you!          11           0
  Parallel hello's to you!          12           0
  Parallel hello's to you!          13           0
  Parallel hello's to you!          14           0
  Parallel hello's to you!          15           0
Simon_Geard
I'm not an expert on openmp but I thought you had to associate the parallel directive with do, workspace or section. Since you're not doing any of these you're not asking it to do anything in parallel. If you were expecting the outpout to appear once for each core then you'll still need to use a loop limited to the number of threads (which you can get with an OMP call). I tried the following variation on my machine which might be of help:
[fortran]
program main
use omp_lib
implicit none
integer :: i, nt
!$omp parallel
nt = omp_get_num_threads()
!$omp do
do i=1,nt
write ( *, '(a,i0)' ) ' Parallel hello''s to you from ',i
end do
!$omp end do
!$omp end parallel
stop
end
[/fortran]
 Parallel hello's to you from 1
 Parallel hello's to you from 4
 Parallel hello's to you from 2
 Parallel hello's to you from 5
 Parallel hello's to you from 3
 Parallel hello's to you from 8
 Parallel hello's to you from 7
 Parallel hello's to you from 6
Note the out-of-sequence numbering which is what you shoud expect when executing a lop in parallel.
farzin_p_
Dear sgeard
I trired your code. but I get this:
why just one thread is recognized?
thanks
Lorri_M_Intel
There are a couple of things I see with your project that was attached in the original posting.
First - while /Qparallel was set, the setting "Language->Generate Parallel Code" was not set (that turns on the /Qopenmp switch).
When I changed that, I saw multiple "Parallel hello's to you" lines.
Also, you're using the DEBUG configuration, which has optimizations turned off.   Ultimately, this may have an effect on a "real" program instead of this prototype.
                     --Lorri
farzin_p_
Dear Lorri,
Special thank for your usefull comment. Problem solved!
thanks everyone :)
