problem with "if"
hamid_mosaddeghi
Dears
I need to insert if statement in "gofr" code, I inserted it in line 174:
if(zzz.ge.1d0.and.zzz.le.3d0)then
and insert "endif" in line 231
after compile i get this errors :
gofr.f(181): error #6099: An ENDDO statement occurred without a corresponding DO or DO WHILE statement.
enddo
gofr.f(189): error #8093: A do-variable within a DO body shall not appear in a variable definition context.
do i=1,9
gofr.f(189): error #6511: This DO variable has already been used as an outer DO variable in the same nesting structure.
do i=1,9
gofr.f(235): error #6317: An ENDIF occurred without a corresponding IF THEN or ELSE statement.
endif
gofr.f(241): error #6099: An ENDDO statement occurred without a corresponding DO or DO WHILE statement.
enddo
why?
I attached two file, gofr.f original and gofr-edited. Please see and help me.
Kevin_D_Intel
With what you inserted, you've broken the if/then block at line 168.
Why are you inserting the endif way down at line 231? And not just at line 180?
[bash]   166         do i=1,natms
   167
   168           if(all.or.name(i).eq.atnam1.or.name(i).eq.atnam2)then
   169
   170             j=j+1
   171             name(j)=name(i)
   172             xxx=xyz(1,i)
   173             yyy=xyz(2,i)
   174          if(zzz.ge.1d0.and.zzz.le.3d0)then
   175             zzz=xyz(3,i)
   176             xyz(1,j)=xxx*rcell(1)+yyy*rcell(4)+zzz*rcell(7)
   177             xyz(2,j)=xxx*rcell(2)+yyy*rcell(5)+zzz*rcell(8)
   178             xyz(3,j)=xxx*rcell(3)+yyy*rcell(6)+zzz*rcell(9)
   179           endif
   180
   181         enddo[/bash]
hamid_mosaddeghi
Dear Davis
if insert "endif" in line 180 , the result isnot acceptable. why?
what's your idea about it?
according the code you guess that if I insert "if" in line 174 and "endif" in line 180 is sufficient!!Ok?
Kevin_D_Intel
I'm sorry. I can't answer those questions. I have no understanding of this code (beyond reading comments). I was just addressing the reason for the compiler errors you caused by your changes.
mecej4
Questions of this type are not likely to be answered here. Asking why some result "is not acceptable" is itself not an acceptable question.
The questions relate to an application area about which most forum members may know nothing about. How are we to know whether results are acceptable or not? We do not even know the problem that your code is solving (nor am I, for one, interested in doing so).
Questions regarding Fortran and how to use the Intel compilers and libraries are appropriate, but you are responsible for developing and debugging the program.
