29657 Discussions
problems with parameters on ifort 11.1.059??
clabra
Yesterday I updated my version of the compiler, and I found a compilation problem of a code who run perfectly with the previous compiler version (11.1.056 intel64).
The error is:
test_materials.F90(186): error #7129: The case-value is out-of-range. [1]
case (curve_constant_type)
test_materials.F90(188): error #7129: The case-value is out-of-range. [2]
case (curve_linear_type)
test_materials.F90(190): error #7129: The case-value is out-of-range. [3]
case (curve_quadratic_type)
test_materials.F90(192): error #7129: The case-value is out-of-range. [4]
case (curve_segments_type)
test_materials.F90(208): error #7129: The case-value is out-of-range. [1]
test_materials.F90(210): error #7129: The case-value is out-of-range. [2]
test_materials.F90(212): error #7129: The case-value is out-of-range. [3]
test_materials.F90(214): error #7129: The case-value is out-of-range. [4]
where cure_*_type are parameters.
The code is attached.
I understand that the code it is ok, but if someone can make some comments about the problem or a possible error on the code...
thaks
Thanks - we'll take a look.
I have not yet been able to reproduce this. Would you please show me the exact compile command you used, as well as adding the -V switch and showing the compiler output?
clabra
Hi Steve,
The command is:
clabra@:function_pointers$ ifort -g -o test.exe -V test_materials.F90
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20091012 Package ID: l_cprof_p_11.1.059
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
Intel Fortran 11.1-2620
compilation aborted for test_materials.F90 (code 1)
and the OS is ubuntu 9.04:
clabra@:function_pointers$ uname -a
Linux xxxx 2.6.27-15-generic #1 SMP Tue Oct 20 06:50:36 UTC 2009 x86_64 GNU/Linux
It is very strange. I hope you can reproduce the error.
Thanks - I can reproduce it now. I have escalated this as issue DPD200141699. For now, I'll suggest that you stick with 11.1.056. We apologize for the inconvenience.
This problem has been fixed in our sources. I expect the fix to be included in Update 5, scheduled for late January.
This was fixed in Update 5.
