29411 Discussions
problems with -shared-intel -mcmodel-large
gogo
I am compiling a Fortran 77 code that contains large common blocks and thus I'm using -mcmodel=large and -shared-intel command line options. However, I'm still getting symbol relocation errors (see output below). It looks like the linker is still attempting to use at least one static library (libifcore.a).
The same problem does NOT occur when compiling with gfortran (same command line options except for -shared-intel). I am using Ubuntu 8.10/kernel 2.6.27 on an intel64 platform. Compiler version is 11.0.081.
Any suggestions?
--George
ifort -g -shared-intel -shared-libgcc -mcmodel=large -o code_larger_array.o -c code_larger_array.f
ifort -g -shared-intel -shared-libgcc -mcmodel=large -o utility.o -c utility.f
ifort -g -shared-intel -shared-libgcc -mcmodel=large -o optmiz.o -c optmiz.f
ifort -o code_large code_larger_array.o utility.o optmiz.o
/opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__message_catalog_close':
for_diags_intel.c:(.text+0x17): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
/opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__io_return':
for_diags_intel.c:(.text+0x82a): relocation truncated to fit: R_X86_64_PC32 against symbol `for__user_iomsg_len' defined in .bss section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x831): relocation truncated to fit: R_X86_64_PC32 against symbol `for__user_iomsg_buf' defined in .bss section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x9ae): relocation truncated to fit: R_X86_64_PC32 against symbol `for__user_iomsg_len' defined in .bss section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0x9b5): relocation truncated to fit: R_X86_64_PC32 against symbol `for__user_iomsg_buf' defined in .bss section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xb10): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xb53): relocation truncated to fit: R_X86_64_PC32 against `tmp_ptr.0'
for_diags_intel.c:(.text+0xbd8): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/081/lib/intel64/libifcore.a(for_diags_intel.o)
for_diags_intel.c:(.text+0xc0a): relocation truncated to fit: R_X86_64_PC32 against `tmp_sev.0'
for_diags_intel.c:(.text+0xc1d): relocation truncated to fit: R_X86_64_PC32 against `tmp_ptr.0'
for_diags_intel.c:(.text+0xc29): additional relocation overflows omitted from the output
make: *** [chr1D_large] Error 1
Ron_Green
Any suggestions?
--George
The LINK needs -shared-intel: this is done by the last 'ifort -o large_code .... ' command in your sequence above.
Also, why are you using mcmodel=large and not =medium? Do you really have over 2GB of compiled code - not data, but code: your text segment (see the 'size' command in linux). I'd recommend using the medium model.
ron
gogo
ron
Yes, of course! I guess I should have had my coffee first and post my question second :) Thanks for your quick response.
Regarding mcmodel=large -- indeed, there is no reason to use it as my code is barely 1MB in size. I was simply hacking with it, since mcmodel=medium didn't seem to work.
Thanks again,
George
