29638 Discussions
problems with using idb on redhatlinux 9
kamaraju
Hi all
I browsed through the web and read the intel forums - but could not find a solution for this problem.
Is anyone able to debug fortran 90 programs (compiled by ifc) using idb on redhat 9? I am getting the following error (I compiled the program with -g option and the executable is in the same directory as that of source code).
Linux Application Debugger for 32-bit applications, Version 7.0, Build 20021021
object file name: a.out
Reading symbolic information ...WARNING: Unrecognized programming language encountered.
Attempting to use C Language rules
Assertion failed: symbolId src/st/file/parsesymsdwarf2.C 5955
This is an unexpected condition and may indicate the presence of a defect.
If you wish to report this, please include the stack trace that follows.
Do not know how to unwind a stack on this machine!!
Linux Application Debugger for 32-bit applications, Version 7.0 caught signal "Aborted" (6).
Do not know how to print a stack traceback on this machine!!
Any work arounds?
thanks in advance
raju
