29359 Discussions
procedure(assign) leads to strange error message
Arjen_Markus
I noticed that using a line like "procedure(assign), deferred:: assign_data" leads to an
error message that bears little or no relevance to the statement:
sort_syntax_error.f90(11): error #5082: Syntax error, found 'ASSIGN' when expecting one of: ) TYPE BYTE CHARACTER CLASS DOUBLE DOUBLECOMPLEX DOUBLEPRECISION INTEGER LOGICAL ...
procedure(assign), deferred :: assign_data
I f I change the name "assign" to something else, the message disappears.
This happens with Intel Fortran 11 on Windows but also with version 12.0.3 on Linux, so I guess
it is a front-end problem.
Here is a small program to reproduce it:
! abstract_sort.f90 --
! Show how to define a generic sortable type
! Module for sortable objects
module sortable_types
type, abstract :: sortable
! No particular data
contains
end type sortable
end module sortable_types
Arjen
Amusing. I'll let the developers know. Even without that, this code needs ASSIGN to have an explicit interface visible, but the error remains when I add this. I wonder if there is some remnant of the pre-F77 CALL ASSIGN left in the compiler...
Arjen_Markus
Sure, it is a fragment of a larger program, but I was really surprised to see this one.
IIRC, ASSIGN was a statement, I have seen it once or twice in an actual program, but
I have never actually used it myself.
Arjen
Yes, ASSIGN is a statement - part of assigned GOTO and assigned formats. These are "deleted features", but we still support them. Issue ID is DPD200173075.
This was fixed in the 13.0 compiler.
