29375 Discussions
program dependent on the 'for_errsns_load' function of libifcoremd.dll
gao_l_
Dear Sir,
I am using Intel FORTRAN v18.0.1.156[IA-32]
I have a project that has set the runtime library to Multithreaded instead of Multithreaded DLL in visual studio.
But the generated executable always depends on the 'for_errsns_load' function of libifcoremd.dll.
What can I do to make it independent of libifcoremd? Can you help me?
andrew_4619
You would be better showing the build options you are using form a buildlog file. There are several options that prevent static build for example any parallel option,
