Hope someone can help me, I use a modal dialog box with an activex control on a quickwin project, when I run the program on Windows 2000 I get a "Program exception in DLGMODAL or DLGMODELESS" runtime error the second time the dialog is called. When debugging, it stops on dlgmodal and if I add dflogm.f90 into the project it stops on dlgdomodal function.
I don't understand what can be wrong because it executes ok when running on Windows 98, Me and XP. I've tested it in two machines with windows 2000 (PRO) with the latest service pack and in both machines it crashes.
Here's the code:
.... CALL COMInitialize (status) ... retlog = DlgSetSub( dlg_tb_verhtml, idd_tb_verhtml, sub_dlg_verhtml_dlg_init, DLG_INIT ) ... retint = DlgModal ( dlg_tb_verhtml ) <-- This is the line where the exception arises call COMUnInitialize () call dlgUnInit(dlg_tb_verhtml) ....
LC
I am having trouble using an ActiveX control. The control is SimpleGrid, a commercially available control from Ocatec. Being commercially available I assume that it is reasonably robust and standard. Using the simplest possible test for it, I am using the Visual Studio generated simple dialog based Windows application using ActiveX controls with the control inserted in the Dialog box. On running the application I get an error in DlgModeless (DlgDoModeless) before the callback routine is called. In CVF 6.6b I get a Visual Fortran run-time error message box with the message: Program exception in DLGMODAL or DLGMODELESS, followed by the usual trace information. In Intel Visual Fortran 8 I get an Application Error message box with the message: The instruction at "0x77f5234c" referenced memory at "0x891c195". The memory could not be "written". On pressing the OK button I get another message box with different memory references.
I have contacted Ocatec who say that as far as they are aware there is nothing non-standard about the control. I haven't had the problem with other ActiveX controls I have used. Does anyone have any ideas? I guess this is going to be difficult to resolve, unless I am missing something obvious.
At this stage, I suggest you submit this to Premier support. Offhand, sounds like a compiler (library) bug, but it's difficult to tell for sure.
Jugoslav
Down loaded many of the commercial versions. Some worked some did not. Most were capable of doing much more than what my interests were. Finally found ubgrid available from www.dev4dev.com (free) Worked Perfect.
I found a workaround for the child dialog issue. If there is an instance of the control on the parent dialog (hidden and disabled if required) then there doesn't seem to be a problem in using the control on a child dialog.
I seem to have a similar problem and would appreciate any thoughts on a solution. I'm using CVF 6.6C and Array Visualizer 1.6.
I'm porting a simulation model to Windows. It uses dlgmodeless to display an Array Visualizerdialog (similar to ANIMWIN32) to display output data - only once at the end of the simulation run.When run as a Win32 console application everything works fine. However, when run as a Win32 application with entry to WinMain() I get the followingafter the dialog appears but before the graph appears:
The instruction at "0x11d9f67" referenced memory at ")x00030003". The memory could not be "read".
The debugger tells me the problem is inAvis2D.ocx.
This behavior does not occur every time thecontrol is invoked; only about 1 time in 4 or 5 - with the same data and compile. Oddly, if I remove the statements that get the share names for the X & Y axis data and use only one sharename to access the surface data I do not get the error in 30+ attempts.And no problem in console mode.
Is this a thread issue or timing problem or what?
