program exception - stack overflow
rafadix08
I received the following message after executing a program:
forrtl: severe(170): Program exception - stack overflow
What do I have to do?
The curious thing is that when I compile the program using just
ifort program.f90
and then execute it, it works fine
however, when I compile using
ifort %FFLAGS% program.f90 %LINK_FNL_STATIC%
and then execute, I get the error message I reproduced above.
PS: I compiled the program using ifort %FFLAGS% program.f90 %LINK_FNL_STATIC% because I will eventually need to call IMSL subroutines.
Thank you,
Rafael
One of the switches in %FFLAGS% is /Qopenmp. This has the side-effect of making all local arrays stack-based instead of static. If you have large local arrays, then you might exceed the 1MB stack one gets by default.
The simple solution is to raise the stack size. Use the /F option to specify a larger stack - the F is followed by a deciimal number for the stack size in bytes. Start with /F10000000 and see if that works - if not, double the number. Repeat as needed. An alternative is to use the option /heap-arrays.
rafadix08
Steve, that worked. Thanks so much!
lklawrie
My recent stack overflow problem -- see other thread was due to an uninitialized variable. But only release compile outside the IDE showed it. Nothing including debug with all turned on did.
Linda
