program hangs when using DEALLOCATE
whistles28
Hi!
I am new here. I use the ifort compiler in with a Xeon based computer (well, actually a cluster but I use only one computer).
Does anyone know what can be happening when my fortran program just hangs at one DEALLOCATE(this_is_an_array) statement?
I checked the state of the array just before the statement and it is allocated
I even wrote
DEALLOCATE(this_is_an_array, STAT=x)
Write(*,*) x
but x never gets to be written.It hangs before this.
the array was defined as allocatable in an external module an later it was allocated in a subroutine.
Is there any compilation option which will allow me to know what's happening?
Francisco
TimP
Quoting - whistles28
Write(*,*) x
Such as IMPLICIT NONE, to assure that you don't fail to declare INTEGER x ? or -check, to perform several run-time checks?
whistles28
Quoting - tim18
As for the IMPLICIT NONE I always use it and therefore it shouldn' be the case.
I am now using -check all - and there are lots of other issues appearing before the problem I described. After I solve these issues I hope I will be able to understand what's wrong with the DEALLOCATE statement. I'll report the result later.
Thanks for the tip!
whistles28
Thanks for the tip!
Problem solved:
The problem was that I had some variables which were used before they were initialized and the arrays related to them became inconsistent. By activating the -check option I managed to detect these problems and correct them.
Thanks again!
Francisco
