program wrong but still running
chljl
I use intel fortran for linux. I found when my program got wrong it still was running and output a lot of "??????????????". I hope it could stop and tell me what is wrong and where it is. Is there any option could do this?
You are using Intel Fortran 7.1 or earlier, right? The ???? means a Not a Number (NaN). If you install and build with Intel Fortran 8.1 and use the -fpe0 option, it will probably give an error message when the NaN is generated. Add -traceback to the build to help narrow it down.
