question about DCMPLX
LeonardB
Hi
The intrinsic function DCMPLX does not change to 128 bit precision when using compiler option /double_size:128. It seems like DCMPLX(x,y) is equal to CMPLX(x,y,kind=8) instead of CMPLX(x,y,kind=KIND(1.D0)). The problem is illustrated in the enclosed program (the same result in IVF11 and IVF12). Is this a bug or a consequence of the fortran standard?
Program Qtst
double complex z
double precision x
call xxx( dcmplx(1.D0,0.D0))
x=0.213D0
z = DCMPLX( x, 0.D0 )
write(*,*) x,z
end
subroutine xxx(x)
double complex x
write(*,*) x
end
Interesting.
DCMPLX is not a standard intrinsic - it is an extension. I would expect /double_size to affect it - CMPLX/DCMPLX seems to be unusual here, since the option does affect SQRT, for example. Escalated as DPD200173396.
Upon further reading, and discussion with the developers, we determined that this is not a bug.
DCMPLX is explicitly documented as returning COMPLEX(KIND=8) and is not affected by /double-size.
CMPLX is standard but the standard specifies that in the absence of a KIND= specifier, the result is complex of default real kind. So without KIND=, CMPLX is not affected by /double-size either but it is affected by /real-size.
The suggestion I have for you is to replace uses of DCMPLX with CMPLX (x,y,KIND=(KIND(1.0D0)). This will do what you want.
