29640 Discussions
question about calling matlab function
张_堃_
hello:
        I'm learning about how to call matlab function by fortran , and I start with the example  matlabroot/extern/ examples/eng_mat/fengdemo.F, here is the code:
#include "engine.h"
#include "fintrf.h"
#if 0
C     fengdemo.F
C     .F file need to be preprocessed to generate .for equivalent
C
#endif
C
C     fengdemo.f
C     This is a simple program that illustrates how to call the MATLAB
C     Engine functions from a FORTRAN program.
C
C Copyright 1984-2005 The MathWorks, Inc.
C======================================================================
C $Revision: 1.9.4.4 $
      program main
C-----------------------------------------------------------------------
C     (pointer) Replace integer by integer*8 on 64-bit platforms
C
      mwpointer engOpen, engGetVariable, mxCreateDoubleMatrix
      mwpointer mxGetPr
      mwpointer ep, T, D
C
C     Other variable declarations here
      double precision time(10), dist(10)
      integer engPutVariable, engEvalString, engClose
      integer temp, status
      data time / 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0 /
      ep = engOpen('matlab ')
      if (ep .eq. 0) then
         write(6,*) 'Can''t start MATLAB engine'
         stop
      endif
      T = mxCreateDoubleMatrix(1, 10, 0)
      call mxCopyReal8ToPtr(time, mxGetPr(T), 10)
C     Place the variable T into the MATLAB workspace
      status = engPutVariable(ep, 'T', T)
      if (status .ne. 0) then
         write(6,*) 'engPutVariable failed'
         stop
      endif
C     Evaluate a function of time, distance = (1/2)g.*t.^2
C     (g is the acceleration due to gravity)
      if (engEvalString(ep, 'D = .5.*(-9.8).*T.^2;') .ne. 0) then
         write(6,*) 'engEvalString failed'
         stop
      endif
C     Plot the result
      if (engEvalString(ep, 'plot(T,D);') .ne. 0) then
         stop
      endif
      if (engEvalString(ep, 'title(''Position vs. Time'')') .ne. 0) then
          stop
      endif
      if (engEvalString(ep, 'xlabel(''Time (seconds)'')') .ne. 0) then
          stop
      endif
      if (engEvalString(ep, 'ylabel(''Position (meters)'')') .ne. 0)then
          stop
      endif
C     read from console to make sure that we pause long enough to be
C     able to see the plot
      print *, 'Type 0 <return> to Exit'
      print *, 'Type 1 <return> to continue'
      read(*,*) temp
      if (temp.eq.0) then
         print *, 'EXIT!'
         status = engClose(ep)
            write(6,*) 'engClose failed'
         endif
         stop
      end if
      if (engEvalString(ep, 'close;') .ne. 0) then
         stop
      endif
      D = engGetVariable(ep, 'D')
      call mxCopyPtrToReal8(mxGetPr(D), dist, 10)
      print *, 'MATLAB computed the following distances:'
      print *, '  time(s)  distance(m)'
      do 10 i=1,10
         print 20, time(i), dist(i)
 20      format(' ', G10.3, G10.3)
 10   continue
      call mxDestroyArray(T)
      call mxDestroyArray(D)
         stop
      endif
      stop
      end
I use  ifort -I '/opt/MATLAB/extern/include' -B '/opt/MATLAB/extern/lib/glnx86'  fengdemo.F  to compile this,but it shows:
tmwtypes.h(125): #error: #if: syntax error.
tmwtypes.h(137): #error: #if: syntax error.
tmwtypes.h(149): #error: #if: syntax error.
tmwtypes.h(161): #error: #if: syntax error.
tmwtypes.h(173): #error: #if: syntax error.
tmwtypes.h(703): #error: #if: syntax error.
tmwtypes.h(776): #warning: keyword redefined: false
tmwtypes.h(779): #warning: keyword redefined: true
tmwtypes.h(790): #error: #if: syntax error.
tmwtypes.h(791): #error:  "This code must be compiled using a 2's complement representation for signed integer values"
features.h(184): #error: #if: syntax error.
features.h(202): #error: #if: syntax error.
features.h(206): #error: #if: syntax error.
features.h(210): #error: #if: syntax error.
features.h(214): #error: #if: syntax error.
features.h(218): #error: #if: syntax error.
features.h(322): #error: #if: syntax error.
cdefs.h(145): #error: #if: syntax error.
cdefs.h(304): #error: #if: syntax error.
stdlib.h(530): #error: incomplete macro call __nonnull.
stdlib.h(532): #error: '#ifdef' argument starts with wrong symbol.
stdlib.h(606): #error: '#ifdef' argument starts with wrong symbol.
stdlib.h(611): #error: #if: syntax error.
features.h(20): #error: '#ifndef' argument starts with wrong symbol.
features.h(21): #error: bad macro name.
features.h(118): #error: bad macro name.
features.h(122): #error: bad macro name.
assert.h(109): #error: #if: syntax error.
I don't know why ,could you help me ?
Judging by the error messages, you're including one or more C headers, which Fortran isn't going to like.
mecej4
The command "ifort /LD /fpp fengdemo.F libeng.lib libmx.lib" will build the MEX file for Win32, provided the Matlab include and library paths have been appended to %INCLUDE% and %LIB% environmental variables.
I do not have Matlab installed for Linux, but you should be able to adapt the above-mentioned build step to Linux.
Timothy_P_Intel
If the include files contain Fortran code, the -fpp option is needed to engage pre-processing.  The .F file naming will do this by default on linux, but not on Windows.
This is the Linux/OS X forum, so I assumed Linux. Also the command line given is Linux/OS X. But the error messages strongly suggest that one of the .h files being #include-ed is for C, not Fortran. You can't mix these. The preprocessor is running, but it is seeing things it doesn't like. Unfortunately, while we can see the Fortran code, which looks fine, we can't see the .h files that are triggering the errors.
Roman1
I have found a file "engine.h" in my Matlab installation, and it is definitely a C include file.  The other include file "fintrf.h" is a Fortran file.
mecej4
It is possible for an include file to be valid when included in a Fortran source file and when included in a C/C++ source file. For instance, if the included file contains #define directives, and the syntax is accepted by a C preprocessor, the preprocessor output may produce correct C code or correct Fortran code after token substitutions are performed.
张_堃_
thank you for your answer ,I sorry that I didn't mentioned  I'm using Linux, and I looked for the user's guide ,it says:
"You do not usually need to specify preprocessing for Fortran source programs.
The preprocessor is necessary only if your program uses C-style preprocessing
commands, such as #if, #define, and so forth.
Intel® Fortran Compiler for Linux* Systems User’s Guide Vol I
If you choose to preprocess your source programs, you must use the
preprocessor fpp, which is the preprocessor supplied with the Intel® Fortran
Compiler, or the preprocessing capability of a Fortran compiler. It is
recommended that you use fpp."
So I think that the preprocessor support this,and this is part of the .h file that cause errors:
# if   INT_MAX  == 0x7FL
# if   LONG_MAX  == 0x7FL
# if   SHRT_MAX  == 0x7FL
And when I use gfortran to compile this ,I get this error message :""You need a ISO C conforming compiler to use the glibc headers"" , so now I'm confused  , although I found that I can use lapack instead of calling  matlab ,but I still want to learn how to use the preprocessor ,thank you very much !
张_堃_
Thank you for your answer ,but  I found that both  "engine.h"  and  "fintrf.h" are  C include files on my computer,I think the intel fortran compile support this  while I found this in it's user's guide:
TimP
Fortran doesn't support the C format for hexadecimal constant. In Fortran, those would be something like z'7f'  (if in 32-bit mode).  I wouldn't be totally surprised if fpp didn't support all the variations of hexadecimal in pre-processing.  The terminology "C-style pre-processing" doesn't mean that C can be translated to Fortran.  It does mean that it's outside the Fortran standard, so you will see differences between gfortran and ifort when you push the boundaries.  There are even differences between the ifort fpp and the open source one.  If you have something which doesn't work with any of the Fortran pre-processors, you can't expect them all to produce the same error messages.
The comment from gfortran  further supports the suggestion that you have C syntax in the include files which can't be pre-processed away even when using a C pre-processor.  As gfortran uses a C89 pre-processor, it may not choke on C code at the pre-processor stage, but that doesn't mean that the result of pre-processing can be accepted as Fortran.  If it's a question of the hexadecimals, the C form has to be acceptable for pre-processing by gfortran because it's processing C code at that stage, where the Fortran hexadecimal wouldn't work in a pre-processor comparison.
张_堃_
Thank for your answer, the .h files and the fortran example are written by Mathworks,  I wonder which fortran compile they use , I asked the same question on their forum , but unfortunately no one answers......
At this point I suggest you ask Matlab support about which include files you should be using. I still think you've got the wrong one(s).
张_堃_
Ok, thank you for your answer
mecej4
张 堃:
I do not know which versions of Matlab and IFort you are using, and whether you are targeting 32-bit or 64-bit. I have access to a system running openSuse 12.3-X64 and Matlab 2007b X-64. On this system, I compiled the Mathworks-supplied fengdemo.F, which contains the line include "fintrf.h", using IFort 13.0.1, using the commands
     ifort -I $MLDIR/extern/include/ -c -fPIC fengdemo.F
     ifort -shared fengdemo.o -o fengdemo.mexa64 -L $MLDIR/bin/glnxa64/ -leng -lmat -lmx
The mex file was produced and I received no warning or error messages.
I recognize that this particular example is intended to be used to build an a.out file rather than a shared object, but at the preprocessing and compiling stages that fact should not matter.
张_堃_
mecej4 wrote:
张 堃:
Thank for your answer, I found I included the wrong file 'engine.h'... Now it seems ok
mecej4
Yes; 'engine.h' is used only in the C examples of using the engine interface.
张_堃_
mecej4 wrote:
Hello, I type the same command as your's on my computer ,but I get this:
ipo: warning #11010: file format not recognized for /opt/MATLAB/bin/glnx86/libeng.so
ipo: warning #11010: file format not recognized for /opt/MATLAB/bin/glnx86/libmat.so
ipo: warning #11010: file format not recognized for /opt/MATLAB/bin/glnx86/libmx.so
can you help me? I run successfully under windows ,but I not so familiar with linux...
mecej4
Which version of Matlab do you use on Linux? You may try turning off -ipo or using an optimization level that does not invoke IPO (InterProcedureOptimizations).
张_堃_
It's 7.10 ,I thought it's may be the environment variable that lead to problem, when I use the engine on windows the first time ,I didn't add the matlabroot/bin/win64 (my windows system is 64 bit and linux is 32 bit )to the environment variable 'PATH' ,and I got the same question ,but after I add the /opt/MATLAB/bin/glnx86 to .bash_profile, the problem is still there...
张_堃_
Sorry ,I found that I my linux is 64 bit ,and I changed the library path ,this time I got :
ld: warning: libut.so, needed by /opt/MATLAB/bin/glnxa64/libeng.so, not found (try using -rpath or -rpath-link)
ld: warning: libhdf5_hl.so.6, needed by /opt/MATLAB/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
ld: warning: libhdf5.so.6, needed by /opt/MATLAB/bin/glnxa64/libmat.so, not found (try using -rpath or -rpath-link)
ld: warning: libmwfl.so, needed by /opt/MATLAB/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
ld: warning: libicudata.so.40, needed by /opt/MATLAB/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
ld: warning: libicuuc.so.40, needed by /opt/MATLAB/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
ld: warning: libicui18n.so.40, needed by /opt/MATLAB/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
ld: warning: libicuio.so.40, needed by /opt/MATLAB/bin/glnxa64/libmx.so, not found (try using -rpath or -rpath-link)
But those files are under /opt/MATLAB/bin/glnxa64 , and I add  /opt/MATLAB/bin/glnxa64 to .bash_profile ...
steve_o_
Hi
Just came across this thread when I was searching for clues. I got this working in OS X 10.10 with latest Matlab 2014b
I was getting the following when compiling naively from the command line
Undefined symbols for architecture x86_64:
  "_mxcopyptrtoreal8730_", referenced from:
      _MAIN__ in fengdemo.o
  "_mxcopyreal8toptr730_", referenced from:
  "_mxcreatedoublematrix730_", referenced from:
  "_mxdestroyarray_", referenced from:
  "_mxgetpr_", referenced from:
ld: symbol(s) not found for architecture x86_64
After some fiddling I got
 ./fengdemo
dyld: Library not loaded: @rpath/libeng.dylib
  Referenced from: /Users/ericnoodle/dummydesktop/build/./fengdemo
  Reason: image not found
Trace/BPT trap: 5
after more fiddling I got
matlab: Command not found.
 Can't start MATLAB engine
so in order to get it to work I did the followingf
from bash, $MLDIR is my Matlab install folder in /Applications
DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$MLDIR/bin/maci64/
and to fix the $PATH
PATH=$PATH:$MLDIR/bin
then compile, link and run
ifort -I $MLDIR/extern/include/ -c -fPIC fengdemo.F90
ifort  fengdemo.o -o fengdemo -L $MLDIR/bin/maci64/ -leng -lmat -lmx
./fengdemo
There may be a more efficient way ? but it works
- hope it helps and it'll be useful for me in a few months time when I forgot what I did ;-)
XXXXXXXXXXXXX:~/dummydesktop/build$ ./fengdemo
1
   time(s)  distance(m)
   1.00     -4.90
   2.00     -19.6
   3.00     -44.1
   4.00     -78.4
   5.00     -123.
   6.00     -176.
   7.00     -240.
   8.00     -314.
   9.00     -397.
   10.0     -490.
