I am having problems with some code. I was able to reproduce what I think is a bug of the compiler on a simple example:
Program Strange
Implicit None
Type Link
Integer, Dimension(2) :: Next
End Type Link
Integer, Parameter :: N = 2
Integer :: i, j
Type(Link), Dimension(:,:), Pointer :: Perm
Integer, Dimension(2) :: Current
Allocate (Perm(N,N))
Print*, 'Spanned by indices'
Do i = 1, N**2
Perm(mod(i-1,N)+1, (i-1)/N+1)%Next = (/ Mod(i,N) + 1, Mod(i/N+1,N)+1/)
Write(*,100) mod(i-1,N)+1, (i-1)/N+1, Perm(mod(i-1,N)+1, (i-1)/N+1)%Next
End Do
Print*, 'Spanned as a cycle'
Current = (/1,1/)
Do i = 1, n**2
Write(*,100) Current, Perm(Current(1), Current(2))%Next
Current = Perm(Current(1), Current(2))%Next
End Do
100 Format( 2I3, '--->', 2I3)
DeAllocate (Perm)
End Program Strange
Here, Mat represent a permutation matrice. The output of the first loop is as follow:
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
Now, in the second loop, Map is spanned as a cycle. The expected output should then be:
1 1---> 2 2
2 2---> 1 2
1 2---> 2 1
2 1---> 1 1
However, Intel Fortran 7.0 returns
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
PGI returns the very same sequence, while an old version of the Fujitsu compiler (1.01), as well as sun 6.0 compiler return the correct answer:
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
Spanned as a cycle
1 1---> 2 2
2 2---> 1 2
1 2---> 2 1
2 1---> 1 1
I am misunderstanding the code I write, I am writing something illegal or are Intel and PGI compiler wrong?
Blaise
Program Strange
Implicit None
Type Link
End Type Link
Integer :: i, j
Do i = 1, N**2
End Do
Current = (/1,1/)
Do i = 1, n**2
End Do
DeAllocate (Perm)
End Program Strange
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
1 1---> 2 2
2 2---> 1 2
1 2---> 2 1
2 1---> 1 1
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
Spanned by indices
1 1---> 2 2
2 1---> 1 1
1 2---> 2 1
2 2---> 1 2
Spanned as a cycle
1 1---> 2 2
2 2---> 1 2
1 2---> 2 1
2 1---> 1 1
Blaise
I took a look at this - the Intel compiler is doing the assignment
incorrectly. I suspect it is starting to update Current before fully evaluating the reference to Perm. The standard says that the right side of the assignment is to be fully evaluated before doing the assignment. Optimizing compilers need dependence analysis to determine whether or not a temporary copy needs to be made, or if it can do the assignment directly. My guess is that the Intel compiler is not getting the analysis right and by the time it goes to write Current(2), it has the wrong index.
Please report this through https://premier.intel.com/ and include my analysis.
Steve
Steve
You are absolutely right.
Indeed, the results displayed by the code I quoted are similar to that computed by the following modification in the last loop,
!!$ Current = Perm(Current(1), Current(2))%Next
Current(1) = Perm(Current(1), Current(2))%Next(1)
Current(2) = Perm(Current(1), Current(2))%Next(2)
which is clearly different.
I don't have access to premier.intel.com yet.
I am actually purchasing the supported version of the compiler, mainly to report this bug, but it takes time...
Blaise
Blaise
If you have the evaluation version, you do have access to Premier Support. Just register using the serial number sent to you.
Let me know if you have trouble doing this.
Steve
Steve
