"The procedure entry point for_error_stop could not be located...
OP1
New Contributor III
Suddenly, I encounter this message while trying to run my code (which compiles fine with  Intel(R) Visual Fortran Compiler XE 14.0.4.237 [Intel(R) 64]...): The procedure entry point for_error_stop could not be located in the dynamic library libifcoremd.dll.
Any suggestion regarding the root cause for this?
Steven_L_Intel1
You probably have a very old copy of libifcoremd.dll on PATH or in the folder of the executable. Alternatively, you have a 32-bit copy of that DLL on PATH and are executing this on a 32-bit only system.
OP1
New Contributor III
Thanks Steve. There was indeed a configuration problem; some strangeness occurred in the VS2013 configuration manager where target platform names got mixed up.
