random number generator
m_p_1
I am testing random generator and what I get in return are hardly random numbers. If I allocate  x with larger size other array elemnts appear to be random but first elemnet is always 0.99*
Can you help what is wrong with the program?
Mark
PROGRAM random_gen
!to test random generator
IMPLICIT NONE
REAL,dimension(1) :: x
INTEGER, ALLOCATABLE :: seed_array(:)
INTEGER :: seed_size,seed_value
INTEGER :: i
CALL RANDOM_SEED (SIZE = seed_size)
ALLOCATE(seed_array(seed_size))
DO i=1,10
CALL extra(seed_value)
PRINT *,seed_value
! seed_array=(/seed_value,seed_value+1/)
seed_array=seed_value
CALL RANDOM_SEED(put=seed_array(1:seed_size))
CALL RANDOM_NUMBER(x)
PRINT *,x
ENDDO
END PROGRAM random_gen
SUBROUTINE extra(val)
IMPLICIT NONE
INTEGER :: val
INTEGER, SAVE :: seed_value
DATA seed_value /0/
seed_value=seed_value+1
val=seed_value
END SUBROUTINE extra
random_gen.x
1
0.9999996
2
0.9999993
3
0.9999990
4
0.9999987
5
0.9999984
6
0.9999981
7
0.9999977
8
0.9999974
9
0.9999971
10
0.9999968
mecej4
You called for initialization of the RNG inside the loop. Had you used the same initial seed each time, you would have seen the same real "random" number each time. As it happened, you used a slightly different seed each time, so the real "random" number also turned out to be only slightly different. Moral: seed sparingly and harvest RNGs as often as you need. Unless you need to and know the implications of doing so, do not specify re-seeding.
