rc.exe
Shalashilin__Dmitry
While compiling a simple Fortran code in Visual Studio 2012 I get:
1>rc.exe not found.
1>
1>Build log written to "file://C:\Data\dima\Path_integral\Parallel_Worlds\PW_2\PW_2\Debug\BuildLog.htm"
1>PW_2 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Can you help?
Steve_Lionel
You must also have a resource file. rc.exe is the resource compiler. It should be provided by VS2012. The first thing I suggest is to go into Tools > Options > Intel Compilers and Tools > Visual Fortran > Compilers. (Depending on which Intel Fortran version you have, the path to this may look a bit different.) Click on the Reset button, then open the x64 tab and click on its Reset button. See if that resolves the problem.
If not, search your computer for rc.exe. It should be under one of the Microsoft folders. Find the path to it and add that path to the "Executable Files" list on the Compilers page.
Shalashilin__Dmitry
Thank you Steve !  It worked
