read statement
tropfen
i have written the following test case to ask if both results are standard conform
[fortran]    program Test_read
    implicit none
character(len=1) :: cValue
open(10,file="temp.txt")
write(10,'(a)')"12345678901234567890"
close(10)
open(11,file="temp.txt")
read(11,'(2x,xa1)')cValue
close(11)
write(6,'(a1)')cValue
open(12,file="temp.txt")
read(12,'(2x,x,a1)')cValue
close(12)
    end program Test_read[/fortran]
both times the write statement is writting 4. Are both read statements (line 10 and 16 ok?)
I am using IVF 11.1.048
Thanks in advance
Frank
mecej4
The formats '(2x,xa1)' and '(2x,x,a1)' are equivalent. You could even have written '(3x,a1)'.
Most compilers do not insist on commas between position edit format items. Why the doubt? What else could have been the output, in your view?
tropfen
in my personal view this should be an error during comliation.
Frank
tropfen
Hello mercj
if your statement is correct then the interpreation of the format items may be unstable
an examble
[fortran]character(len=10) :: cValue10
real*4 :: rValue
open(13,file="temp2.txt")
write(13,'(a)')"N00001.1"
close(13)
open(14,file="temp2.txt")
read(14,'(a,1f7.1)')cValue10,rValue
close(14)
write(6,'(a10,x,f7.1)')cValue10,rValue
read(14,'(a1,f7.1)')cValue10,rValue
close(14)
read(14,'(a1f7.1)')cValue10,rValue
close(14)
write(6,'(a10,x,f7.1)')cValue10,rValue[/fortran]
the output is:
N00001.1 0.0
N 1.1
N 1.1
In my point of view the compiler should produce at least a warning
Frank
mecej4
I agree that a warning on a missing width n in the 'nX' specifier would be helpful. Similarly for missing commas.
Your second example, however, confuses the issue. Here, the culprit is not the missing commas or position specifiers, but your use of the '(a,1f7.1)' format in your first READ. Format 'a', with no field width specified, takes the field width to be the length of the corresponding I/O list variable. In your example, this length is 10. Therefore, the second item in the I/O list, rValue, is read from columns 11 onwards in the input line. However, those columns simply contain blanks added as padding, and the read value is zero, in the absence of a BLANK=<'null' | 'zero'> specifier in the file open statement.
To see this, fix all the X format edit descriptors by adding a count and by adding commas. You will still see the same behavior.
If you enable standards checking, you'll get:
t.f90(10): warning #7423: Fortran 2003 requires a count prefix for the X edit descriptor. [x,xa]
t.f90(10): warning #6893: In a format list, the required delimiter is missing. This is an extension to Standard F2003. [x,xa]
t.f90(16): warning #7423: Fortran 2003 requires a count prefix for the X edit descriptor. [x,x,a]
tropfen
Hello Steve,
i am using IVF 11.1.048 without any changes. Do i have to change the settings to have your 'standard checking' or are those 'standard checks' part of a newer IVF version?
Frank
TimP
11.1 has standards checking flags up through f2003. It's possible in some cases they may not be as strict as the newer versions. If it's not a Visual Studio property menu item, you can add a command line option.
It is a property under Diagnostics > Warn for non-standard Fortran. I have not tried the code under 11.1 to see if it reports these extensions.
tropfen
Hello Steve,
you are writting that those test are part of the standard checking. Today i have installed the current ivf version (12.1.1.258). I have tested the above examble. With the standard installation the checking for non standard fortran (Diagnostics > Warn for non-standard Fortran) has not been aktivated.
Frank
IanH
Are you saying that you needed to set the property from within Visual Studio (I imagine that there are a number of people that don't want standards checking on by default), or that with that property set you didn't see warnings (I see them here)?
Wendy_Doerner__Intel
Valued Contributor I
Yes Ian is correct, standards checking is not on by default (different customers want different standards to be checked and some do not want standards checking). You will need to set it.
Wendy
Attaching or including files in a post
The results I showed were using the 12.1 compiler.
