reading a string error
kooka
I am retriving values fron edit boxes to a real*4 variable. My program is so freak, I am working in a program thath uses quikwin and win32. When i retrieve them from a dialog box thath i display with quickwin routines there is no problem, but when i do it from a win32 dialog box, there is a problem in reading thath data, i paste my code in both quikwin and win32:
QUICKWIN: !works perfectly
real*4 gamma
character*20 str
bret = DLGGET(dlg, IDC_GAMMA, str)
READ(STR,*) GAMMA
WIN32 !DOESN'T WORKS
real*4 apsl
character*20 str
IRET=GETDLGITEMTEXT(HDLG,IDC_apsl,str,20)
READ(STR,*) apsl
I think there is a problem with the blanks in the STR variable, but im not sure
I WILL REGRET YOUR HELP
kooka
in effect there is a problem with blanks because when i input less than 20 characters there's an error, when i input 20 or more there is not an error, but that problem is not present when i use quickwin routines. But i must use win 32 in this part of the program
The Win32 version returns a string that is NUL-terminated, as in C. Fortran I/O doesn't like that. You'll need to use INDEX to find the position of the NUL (CHAR(0)) and read from the substring that is the actual text.
kooka
tanks for your help!, it works now
