reading big endian file?
steve_o_
I'm trying to read a big endian file from http://yann.lecun.com/exdb/mnist/
So far I open the file as in a test program
Program Arraytest3
   	Type magic
       	        byte :: byte1  ! INTEGER(1)
  		byte :: byte2
  		byte :: dataType
  		byte :: dimentions
     END Type magic
    Type Images
 		Type(magic) :: magic_number
  		INTEGER(kind=4) 	:: numberOfImages
  		INTEGER(kind=4) 	:: numberOfRows
  		INTEGER(kind=4) 	:: numberOfColumns
  		byte        :: imageCount(1)
  	END Type Images
    Type (Images) :: idx
open(10, CONVERT='LITTLE_ENDIAN',file='t10k-images-idx3-ubyte', access='stream', status='old', FORM='BINARY')
    read(10), idx
    close(10)
    !! Need to byteFlip each byte
    print*,"numberOfImages", idx%numberOfImages
    print*,"numberOfRows", idx%numberOfRows
    print*,"numberOfColumns", idx%numberOfColumns
    print*,"magic_number", idx%imageCount(1)
   print*,"Should be 10000 28x28 images"
end Program Arraytest3
referencing the intel page here https://software.intel.com/en-us/node/524834 none of the key words seem to have any effect the result always being the same
 numberOfImages   270991360
 numberOfRows   469762048
 numberOfColumns   469762048
Now if I put these numbers into my calculator and byte flip them then I get the expected result. Does this mean Convert doesn't work on derived types?
mecej4
steve o. wrote:
PS whats the difference here in the picture from the ref page or am I being dyslexic?
https://software.intel.com/sites/default/files/managed/08/83/9C8C9E9B-FE4F-4EB1-B850-8CEC8A8B0618-imageId=A6A0C0E1-C865-422E-A2A0-2AD5BE5BBE73.jpg
My eyes are used to big-endian decimal strings, but it appears that the image is a work-in-progress. Moreover, I have not traced the link back to any text, so ...
Here is a modification that works on Suse-Linux, but works by cheating the compiler to do something that is not provided for
Program Arraytest3
        Type magic
                sequence
                byte :: byte2
                byte :: dataType
                byte :: dimentions
     END Type magic
    Type Images
                sequence
        END Type Images
    integer :: iidx(4)
    equivalence(iidx,idx)
open(10, CONVERT='BIG_ENDIAN',file='t10k-images-idx3-ubyte', access='stream', status='old')
    read(10), iidx
    close(10)
TimP
If you want conversion from big-endian, why do you specify that the file is little_endian?
mecej4
Redundant/conflicting specifiers in OPEN can lead to problems. Remove access='stream' from the OPEN statement.
See https://software.intel.com/en-us/node/524840#A8125889-2623-465B-963D-3678F2D5DEC1, where it says "Converted data should have basic data types, or arrays of basic data types. Derived data types are disabled."
steve_o_
Hi Tim
Thats just the last copy of the code, I tried all the options
steve_o_
Hi @mecrj4
I did see that link you posted, it was the first thing I tried, but it didn't work for me for the reason given, however surely that restriction only applies to the use of F_UFMTENDIAN=little;big:10,20 which is what I had my shell env variable set to
I tried removing stream and setting convert to IBM, BIG_ENDIAN without success - I guess that the restriction also applies to structures here despite not being stated.
mecej4
Program Arraytest3
        Type magic
                sequence
                byte :: byte2
                byte :: dataType
                byte :: dimentions
     END Type magic
    Type Images
                sequence
        END Type Images
    integer :: iidx(4)
    read(10), iidx
    close(10)
steve_o_
It appears you can't use structures, the following works though, sorry for the messy code ;-)
Program Arraytest3
	byte   ::  m1, m2, m3, m4
	Integer(kind=4) :: I, R, C
   	Type magic
  		byte :: byte2
  		byte :: dataType
  		byte :: dimentions
     END Type magic
    Type Images
  	END Type Images
    open(10, CONVERT='IBM',file='t10k-images-idx3-ubyte',  status='old', FORM='BINARY')
    read(10), m1
    read(10), m2
    read(10), m3
    read(10), m4
    read(10), I
    read(10), R
    read(10), C
    close(10)
    print*,"numberOfImages", I !idx%numberOfImages
    print*,"numberOfRows", R !idx%numberOfRows
    print*,"numberOfColumns", C ! idx%numberOfColumns
numberOfImages       10000
 numberOfRows          28
 numberOfColumns          28
steve_o_
Sorry, our postings seemed to cross
Just tried your code on OS X 10.9.5 and it also works, however it does flag the following warning
arraytest3.f90(12): warning #6380: The structure length is not a multiple of its largest element; could create misalignments for arrays of this type.   [IMAGES]
    Type Images
I wouldn't have thought of doing it your way, thanks ;)
Not to worry - fixed it
I did read that this is an obsolescent feature in Fortran 90/95 - guess it should be safe to use for 40 years or so
mecej4
That warning is issued on Linux, too, but it pertains to arrays of type IMAGES. If you do create an array later, you could pad the type with enough junk bytes to align to 8-byte or 16-byte boundaries, or change the type of ImageCount to INTEGER.
Steven_L_Intel1
At present, we do not do CONVERT= on components of derived types/structures. This is a historical artifact due to our support of UNIONs and we've discussed changing it, but it would introduce an incompatibility.
steve_o_
Thanks Steve
I have it working now - in case anyone else is looking for a fortran mnist file reader (http://yann.lecun.com/exdb/mnist/ ) in future - I converted the unsigned bytes in the file to an array of 16 bit integers which seems to have done the trick (the values of the file represent gray scale images from 0 to 255 apparently) Hopefully my use of zext is correct - it seems to give reasonable results
Now to plumb it into my Boltzmann Machine code
Program Arraytest3
	INTEGER :: AllocateStatus, I
    Type Magic
        sequence
        byte :: byte2
        byte :: dataType
        byte :: dimentions
     END Type Magic
    Type Images
        Sequence
        Type(magic) 		:: magicNumber
    END Type Images
    INTEGER(2), 	DIMENSION(:,:,:), ALLOCATABLE :: imageMatrix
    INTEGER(1), 	DIMENSION(:,:), ALLOCATABLE :: buffer
    INTEGER :: iidx(4)
    Equivalence(iidx,idx)
    read(10), iidx
    ALLOCATE(  imageMatrix(idx%numberOfColumns,idx%numberOfRows,idx%numberOfImages), &
    	buffer(idx%numberOfColumns,idx%numberOfRows) , STAT = AllocateStatus)
    IF (AllocateStatus /= 0) STOP "*** Not enough memory, try a smaller network ***"
    Do I=1, idx%numberOfImages
	read(10), buffer
	imageMatrix(:,:,I) = zext(buffer)
    EndDo
    close(10)
    DEALLOCATE( buffer)
    print*, imageMatrix(:,:,10)
    DEALLOCATE( imageMatrix )
