29578 Discussions
reading from a binary file single precision to double precision
diedro
dear all,
I have the following problem. I Have to read a binary file written in single precision:
  OPEN(1,file=input_rain_file,STATUS='old', form='BINARY')
 !TEMP A SINGLE PRECISION VARIABLE
  DO i=1,nmacro
     READ(1) TEMP(:,i)       ! in [mm], single precision
  END DO
and then I apply
DOUBLEP = TEMP
I do not know if this is formally correct and if I can directly read the single precision file using a variable in double precision.
Thanks in advance for any help
Diego
mecej4
I do not know ... if I can directly read the single precision file using a variable in double precision.
The number of bytes in the record being read is equal to the byte-size of the I/O list. If you write a number of REALS and then read them as DOUBLE, chaos will result, because record length bytes and enough bytes from the next input record will be read in order to fulfill the READ request.
diedro
Dear all,
thanks. There is a smart way to overcome this?
For example, imposing a format in the reading statement?
Thanks again
Diego
jimdempseyatthecove
You can conserve memory by reading one row at a time:
! TEMP A SINGLE PRECISION VARIABLE
! REAL(4) :: TEMP(nCols)
REAL(8) :: DOUBLEP(nCols,nMarco)
 DO i=1,nmacro
    READ(1) TEMP(:)       ! one row in [mm], single precision
    DOUBLEP(:,i) = TEMP
 END DO
If memory is not an issue, you can (may be able to) read the whole array as sp in one READ, then convert as done before.
Jim Dempsey
