real precision conversion
fbisetti
Hi all,
I have a question about the generic elemental function REAL(a[,kind])
Does the function work element by element if the input argument 'a' is an array? In other words, does the following work correctly?
! -- code start
real(4) :: x(10)
real(8) :: y(10)
call random_number(y); x=real(y,4)
! -- code end
If this works, does it work regardless of the number of dimensions of the array (1D, 2D, ...)?
The reason that I'm asking it that I got a SEGFAULT when trying to something similar in a code, but in other occasions, it seemed to work fine. This left me confused and I wanted to check. The language reference document doesn't seem to mention the shape of the input argument.
Thanks a lot,
Fabrizio
REAL is elemental, so if you pass it an array argument of any shape it will return an array of the same shape. The manual says it is elemental and thus you need to go read what that means.
fbisetti
Thanks a lot,
Fabrizio
