reinterpret cast for arrays
tom_p
I would have thought the following is a common problem, but I did not find a satisfactory solution: Many subroutines defined for real arrays work as well for a complex array if it is interpreted as a real array of double size. For example some of our programs do this:
[fortran]subroutine callee(arr, N)
integer, intent(in) :: N
real, dimension(1:N), intent(in) :: arr
! do stuff
end subroutine callee
subroutine caller()
complex, dimension(1:10) :: arr
call callee(arr, 20)
end subroutine caller
[/fortran]
This actually compiles and works if callee is defined in an external subprogram, but of course it violates the standard and breaks if the gen-interfaces compiler switch is used.
Is there any "clean" solution to do this, apart from defining callee twice (once for real and once for complex arguments)? An equivalence statement is not an option as it cannot be used with dummy arguments.
I'd also like to ask the same question with regard to multi-dimensional arrays interpreted as one-dimensional. Here I could of course use the reshape intrinsic, but that implies a lot of copying and therefore cannot generally be used.
(As a side note: the gen-interfaces switch generates interfaces but no compile time error if an external statement exists; is this the intended behavior?)
There are various ways to handle this. First, Intel Fortran has an extension called the NO_ARG_CHECK attribute. When this is specified on a routine or a dummy argument, it disables compile-time checks for type, rank and kind. So you could add:
!DEC$ ATTRIBUTES NO_ARG_CHECK :: arr
in "caller" to avoid the generated interface errors.
The Fortran TRANSFER intrinsic is sort of like reinterpret_cast in that it gives you a result with the same bits, just as a different type.
You can also do something like this:
  use iso_c_binding
integer, intent(in) :: N real, dimension(1:N), intent(in) :: arr complex, dimension(:), pointer :: p_arr call c_f_pointer (c_loc(arr), p_arr, [N/2]) ! do stuff with p_arr end subroutine callee[/fortran]
A third option is to use generic interfaces that all bind to the same routine using ALIAS.
I can't reproduce the issue you raise regarding EXTERNAL. Can you show an example?
  use iso_c_binding
tom_p
Thanks a lot for your answer. I must admit I did not understand your third option; if I understand correctly, ALIAS creates a different name for a subroutine visible from the outside, but I do not see how this could be used to override the argument check.
As to the issue of the compiler failing to emit a warning, no wonder you could not reproduce this because it apparently only occurs if the external subroutine is not called from the main program but only in a subroutine. Minimal example:
[fortran]! calltest.f90
program calltest
  implicit none
  external callee  ! if this is commented out ...
  ! ... or if callee() is called here the compiler notices the
  ! interface mismatch
  call main()
contains
  subroutine main()
    integer, parameter :: N = 10
    complex, dimension(1:N) :: arr = 0
    call callee(arr, 2*N)
  end subroutine main
end program calltest
! callee.f90
  implicit none
  print *, arr
[/fortran]
No error is generated with Intel Fortran 10.1 for Windows and 11.1 for Linux with the command "ifort -warn all -gen-interfaces callee.f90 calltest.f90".
PS: The syntax highlighter of this forum seems to have a problem with Internet Explorer 7. The code looks okay in the edit window, but in the preview the line breaks have vanished.
The "external" issue you mention is one that has been reported before and will be fixed.
My suggestion regarding alias was a way to have two (or more) signatures for a single routine. For example:
[fortran]interface mysub
subroutine mysub_real (x)
!dec$ attributes alias:"mysub_generic" :: mysub_real
real, dimension(*) :: x
end subroutine mysub_real
subroutine mysub_complex (x)
!dec$ attributes alias:"mysub_generic" :: mysub_complex
complex, dimension(*) :: x
end subroutine mysub_complex
end interface
subroutine mysub_generic (x)
!dec$ attributes alias:"mysub_generic" :: mysub_generic
real, dimension(*) :: x ! or whatever you want
end subroutine mysub_generic
[/fortran]
