reinterpreting complex as reals
Todor_K_
Consider the following trick,
module xxx
  implicit none
  integer, parameter :: stdprec=kind(1.d0)
contains
  function conv2real(carr)
    use, intrinsic :: iso_c_binding
    ! returns real pointer to a complex array
    complex(stdprec), contiguous, intent(inout), target  :: carr(:)
    real(stdprec),contiguous,pointer :: conv2real(:)
    call c_f_pointer(c_loc(carr),conv2real,[size(carr)*2])
  end function conv2real
end module xxx
The function conv2real takes a complex array as argument and , with the help of c binding module, returns a real pointer to it.
First question: is Fortrand standard OK with this technique? I think it should be.
Second question: Is this violating ansi aliasing? I think not, since complex numbers are just pairs of reals, no weird reinterpreting is going on.
Now, consider the following test case
module xxx
  implicit none
contains
end module xxx
program zorglub
  use xxx
  implicit none
  complex(stdprec), contiguous, pointer :: x(:)
  real(stdprec), contiguous, pointer :: rx(:)
  type ccc
    complex(stdprec), contiguous, pointer :: p(:)
    real(stdprec), contiguous, pointer :: rp(:)
  end type ccc
  type(ccc) :: o
  !sequence of steps: allocate, point real to complex, then initialise complex
  allocate(x(100))
  rx=>conv2real(x)
  x(1)=1.23_stdprec
  print *, x(1)
  print *, rx(1) !real part of x(1) == rx(1) CORRECT
  allocate(o%p(100))
  o%rp=>conv2real(o%p)
  o%p(1)=1.23_stdprec
  print *, 'p', o%p(1)
  print *, 'rp', o%rp(1) !real part of o%p(1) /= o%rp(1) !!! WRONG (BUG?)
  !do some clean up and reuse
  deallocate(o%p)
  nullify(o%p)
  nullify(o%rp)
  !sequence of steps: allocate, then initialise complex, then point real to complex
  allocate(o%p(100))
  o%p(1)=1.23_stdprec
  print *, 'rp', o%rp(1) !real part of o%p(1) == o%rp(1) !!! CORRECT
end zorglub
I am first allocating the complex x pointer , then pointing rx to it. Afterwards, I initialise x(1) and print both x and rx. Both yield the same , expected result.
However, when I make a derived type containing a complex and a real array pointer, repeat the previous procedure, I get different values for o%p(1) and o%rp(1) . I think this is a bug.
The last bit of the test is a printout of o%p and o%rp, but this time, the first value of o%p is initialised _before_ the o%rp is made to point to o%p . So, the steps are reversed in respect to the preceding examples. Now again the pointer and its target have the same value at the first index.
Lastly, when I replace 'target' in function conv2real with 'pointer', everything seem to work correctly.
The ifort compiler version is 16.0.2
The first bit of code doesn't violate the standard as the dummy argument has the TARGET attribute.
Your full program (which contains a minor syntax error) gives me identical results for all cases in 17.0.1, but not in 16.0.2 (which is what I happen to have on this system.)
