relocation truncated to fit
SL00
Dear all,
When I compile my Fortran code, I got the following error,
ipo_out1.f:(.text.hot00002+0x9a): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_ilnrho_' defined in .bss.cdata_mp_ilnrho_[cdata_mp_ilnrho_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x105): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_t_' defined in .bss.cdata_mp_t_[cdata_mp_t_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x136): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_ilnrho_' defined in .bss.cdata_mp_ilnrho_[cdata_mp_ilnrho_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x383): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_lfirstpoint_' defined in .bss.cdata_mp_lfirstpoint_[cdata_mp_lfirstpoint_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x390): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_imn_' defined in .bss.cdata_mp_imn_[cdata_mp_imn_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x39b): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_necessary_' defined in .bss.cdata_mp_necessary_[cdata_mp_necessary_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x3aa): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_mm_' defined in .bss.cdata_mp_mm_[cdata_mp_mm_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x3b9): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_nn_' defined in .bss.cdata_mp_nn_[cdata_mp_nn_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x3d5): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_n_' defined in .bss.cdata_mp_n_[cdata_mp_n_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x3dc): relocation truncated to fit: R_X86_64_PC32 against symbol `cdata_mp_m_' defined in .bss.cdata_mp_m_[cdata_mp_m_] section in /tmp/ipo_ifort4MDURv1.o
ld: ipo_out1.f:(.text.hot00002+0x462): additional relocation overflows omitted from the output
ld: failed to convert GOTPCREL relocation; relink with --no-relax
The largest array size in my simulation is 17 times smaller than "2^(31)-1"
System: CentOS release 6.10
Intel: intel/2019.1.144-GCC-8.2.0-2.31.1/impi/2018.4.274/bin64/mpiifort
Any idea about how this happens?
Sean Lee
Juergen_R_R
Valued Contributor II
This looks like mixing compilers and libraries from different systems mixed up, either 32bit vs. 64bit or installations for ifort and mpiifort based on different glibc or something similar.
SL00
Thanks a lot, Juergen.
I checked my compiler and it is indeed 64 bits,
Any idea about fix this?
Juergen_R_R
Some component in your project is 32bit, some compiler, some external library, or some linker. Try to find out which.
jimdempseyatthecove
Note, it is not the size of an individual array that matters, but rather the sum of the sizes of the static arrays. To correct for this, make your largest arrays allocatable (and initialize from file if necessary).
Jim Dempsey
