return required on function?
larson__michael
NEVERMIND.... I figured it out...
Hi I am working on re-learning modern Fortran by working through the Project Euler examples.
In writing a fibonacci function a "return" is required to actually get the result pushed back, I seem to remember that was required in F77..
I would suspect that
     f = fibonacci(x)
Would be enough but through trial and error I found that issuing a "return" at the end of the fibonacci function makes it all work correctly. But this is contrary to just about any fortran example I have seen posted on the web
Thanks ahead of time
! PROBLEM 2
integer function fibonacci(x)
  implicit none
  integer :: x
  integer :: i
  integer :: x_m_1, x_m_2
  if (x == 0) then
     fibonacci = 1
  elseif (x == 1) then
     fibonacci = 2
  else
     x_m_1 = 2
     x_m_2 = 1
     fibonacci = 0
     do i = 2,x
        fibonacci = x_m_1 + x_m_2
        x_m_2 = x_m_1
        x_m_1 = fibonacci
        if (fibonacci < 0) then
           stop
        end if
     end do
  end if
  return
end function fibonacci
subroutine problem_2
  implicit none
  integer :: sum = 0
  integer :: even_sum = 0
  integer :: x = 0
  integer :: f
  integer :: fibonacci
  do while (f <= 4000000)
     f = fibonacci(x)
     !print *, "Fibonacci ", x, " = ", f
     sum = sum + f
     !print *, "sum = ", sum
     if (mod(f, 2) == 0) then
        even_sum = even_sum + f
     end if
     !print *, "even_sum = ", even_sum
     x = x + 1
  end do
  print *, "Sum is ", sum
  print *, "Even Sum is ", even_sum
end subroutine problem_2
GVautier
New Contributor III
F is not initialized before the do while loop so it may never enter
larson__michael
good point... woops.
