29386 Discussions
run-time calculation give different results than compile-time calculation.
John_D_B_
This is my first post. I appoligize in advance.
short program:
program prime_number_table
implicit none
integer(kind=8), parameter :: MAX_PRIME = 4294967295 ! 2**32-1
integer(kind=8), parameter :: ROOT_MAX = int(sqrt(real(MAX_PRIME,8)),8)
integer(kind=8), parameter :: PI_MAX_PRIME = 150000
write(*,*) "MAX_PRIME: ", MAX_PRIME
write(*,*) "real(MAX_PRIME): ", real(MAX_PRIME,8)
write(*,*) "sqrt(real(MAX_PRIME)): ", sqrt(real(MAX_PRIME))
write(*,*) "int(sqrt(real(MAX_PRIME))): ", int(sqrt(real(MAX_PRIME)),8)
write(*,*) "ROOT_MAX: ", ROOT_MAX
read(*,*)
end program prime_number_table
Results:
MAX_PRIME: 4294967295
real(MAX_PRIME): 4294967295.00000
sqrt(real(MAX_PRIME)): 65536.00
int(sqrt(real(MAX_PRIME))): 65536
ROOT_MAX: 65535
Is this a bug or a feature?
compiler version: Intel Visual Fortran Composer XE 2011 Integration for Microsoft Visual Studio* 2005, 12.0.3471.2005, Copyright (C) 2002-2011 Intel Corporation
Thank you very much in advance.
John D Bauer
rasa
Lets Try this one.
[bash]program prime_number_table
implicit none
!-- Kinds for specified real precisions.
integer, parameter :: r4_kind = selected_real_kind(6,30)   !-- 6 digits
integer, parameter :: r8_kind = selected_real_kind(12,30)  !-- 12 digits
!-- Kinds for specified integer ranges.
!-- Caveat: Not all compilers have a suitable i8_kind.
integer, parameter :: i1_kind = selected_int_kind(2)  !-- 99 max
integer, parameter :: i2_kind = selected_int_kind(4)  !-- 9,999 max
integer, parameter :: i4_kind = selected_int_kind(9)  !-- 999,999,999 max
integer, parameter :: i8_kind = selected_int_kind(18) !-- 10**18-1 max
integer(kind=i8_kind), parameter :: MAX_PRIME = 4294967295           ! 2**32-1
integer(kind=i8_kind), parameter :: ROOT_MAX = int(sqrt(real(MAX_PRIME,r8_kind)),i8_kind)
integer(kind=i8_kind), parameter :: PI_MAX_PRIME = 150000
write(*,*) "real(MAX_PRIME): ", real(MAX_PRIME,r8_kind)
write(*,*) "sqrt(real(MAX_PRIME)): ", sqrt(real(MAX_PRIME, r8_kind))
write(*,*) "int(sqrt(real(MAX_PRIME))): ", int(sqrt(real(MAX_PRIME, r8_kind)),i8_kind)
read(*,*)
[/bash]
Output goes.
[bash] MAX_PRIME:             4294967295
 sqrt(real(MAX_PRIME)):    65535.9999923706
 int(sqrt(real(MAX_PRIME))):                  65535
 ROOT_MAX:                  65535
[/bash]
HTH.
The key here is that:
real(MAX_PRIME,8)
as in the definition of ROOT_MAX
is not the same as:
real(MAX_PRIME)
in the WRITE that is different. The second one returns a single precision REAL value which does not have enough precision to hold MAX_PRIME.
John_D_B_
real(MAX_PRIME,8)
is not the same as:
real(MAX_PRIME)
Thank you very much. the program from the compilers point of view reads:
implicit none
write(*,*) "MAX_PRIME: ", 4294967295
write(*,*) "real(MAX_PRIME): ", real(4294967295,8) ! This is 64-bit floating point
write(*,*) "sqrt(real(MAX_PRIME)): ", sqrt(real(4294967295)) ! This is 32-bit floating point
write(*,*) "int(sqrt(real(MAX_PRIME))): ", int(sqrt(real(4294967295)),8) ! The square root return a 32-bit
! floating point number
write(*,*) "ROOT_MAX: ", 65536
read(*,*)
to be continued.....
