runtime crashes
hai_p_
I am currently moving a large code base over to the Intel fortran compiler. This task is almost complete, and the code is now executing as expected, however visual studio 2010 keeps crashing while I am debugging. These crashes occur either when stepping into a particular procedure, or when hitting a break point inside of the procedure. I receive the error message: Microsoft visual studio has stopped working. windows is checking for a solution to the problem... The studio then restarts with no explanation as to what caused the crash. Curiously, if I step over these procedures, they run fine and my debug session continues.
I understand there is not a lot to go on here, but I would appreciate any suggestions
IanH
Have you installed Visual Studio 2010 service pack one?
Yu__Tao
I met the same problem with you when I used VS2010 to debug Fortran and C++ code. But after I moved to VS2012, it never happens.
andrew_4619
I have seen that myself. I think the cause is stack corruption usually down to call interface bugs in your code.
Bernard
Valued Contributor I
Looks like VS debugger thread crash probably dreaded access violation error. In order to find what could went wrong you can check event viewer and look for Application Error entry.
