runtime error line number
wen
I am using IVF v.9.1.025 in windows, IA32, to test a simplified piece of code:
program runErr
integer :: i
open( 11, file='abc.txt')
read (11,"(i2)") i
end program runErr
The first line in the input file abc.txt is just a string abc.
On the DOS command line, I ran
iFort runErr.f90 /Zi /Od /warn:declarations /warn:interfaces /warn:uncalled /warn:unused /traceback /check:all /RTCu /threads /dbglibs
to compile/link runErr.f90
The runtime error message told me that there was an input conversion error for unit 11, file abc.txt. It listed eleven locations with unknown routine, unknown line, and unknown source.
How to make it tell me the line number and routine name or source name for the location of the runtime error?
Wen
Interesting - the /Zi causes the traceback to go away. I'll ask why.
wen
Thank you, Steve.
The Link option /debug has the same effect as /Zi we have discussed.
I ran
iFort runErr.f90 /c /traceback
iFort runErr.obj /debug
the runtime error did not show the line number for the line with error.
When I removed the option /debug and ran
iFort runErr.obj
the line number appeared.
Wen
/debug is the same as /Zi. I've escalated this to development.
"Light dawns on Marblehead," as we say here in New England. The problem is that /debug (or /Zi) implies incremental linking and that disables traceback. You can fix this by adding:
/link /incremental:no
to the end of the command line (after source file names). I've suggested to the developers that the ifort driver do this automatically if /traceback is specified. Note that in Visual Studio, incremental linking is disabled in a Debug Fortran configuration.
drgfthomas
Also, in release config. it would be useful to have Omit Frame Pointers default to 'No' if runtime Traceback is 'Yes'. The default appears to be 'Yes' which doesn't disable Traceback but limits its usefulness.
