same .exe different results
cr362
Dear All,
Sorry if this is a strange question, but is there any reason why the same .exe (only compiled once) will produce different results? The code is exactly the same, as are the inputs. I run the code once, and then run it again but get a different result. The difference is small (0.01), but this is still important for my code.
Thanks, and if you need any more info then let me know.
TimP
Uninitialized variables? bounds violations?
