29411 Discussions
same_type_as() in constant expressions
DataScientist
Valued Contributor I
The expression,
integer, parameter :: offset = merge(1, 0, same_type_as(x_type(), y_type()))
yields an error with ifort (but not with gfortran).
error #6263: This intrinsic function is invalid in constant expressions. [SAME_TYPE_AS]
Which behavior is standard-conforming?
Steve_Lionel
It is definitely a bug. I thought I had submitted a ticket on specification inquiry expressions a longtime ago but can't find it in my issue history. The Intel compiler completely misses the standard's support of these in constant expressions.
Steve_Lionel
My opinion is that Intel is correct. SAME_TYPE_AS() here is a "specification inquiry" (which Intel has gotten wrong before), but the restrictions on using this in a constant expression are:
a specification inquiry where each designator or argument is
 (a) a constant expression or
 (b) a variable whose properties inquired about are not
   (i) assumed,
   (ii) deferred, or
   (iii) defined by an expression that is not a constant expression,
In this case, xtype() and ytype() aren't constant expressions nor variables. (Since you didn't include the definition of these, I don't know what they are, but the syntax does tell me they don't qualify.)
DataScientist
I expected that the following would be standard conforming, but Intel ifort issues a compile error (unlike gfortran):
type :: x_type; end type
type :: y_type; end type
type(x_type), parameter :: x = x_type()
type(y_type), parameter :: y = y_type()
integer, parameter :: offset = merge(0, 1, same_type_as(x, y))
print *, offset
end
I do not see why this should not be standard-conforming. Everything is compile-time constant. Here is a test: https://godbolt.org/z/G65aaj6e5
Steve_Lionel
I think this is the more general case of Intel Fortran not properly supporting specification inquiries in constant expressions.
DataScientist
Can we say this is an ifort BUG so that it hopefully gets picked up by the developers?
Steve_Lionel
DataScientist
Thank you. I cannot change the title anymore to add a BUG tag. But if you have already submitted a ticket, that should be enough.
Barbara_P_Intel
@Steve_Lionel, I couldn't find a bug report on this invalid error message, but maybe my search skills are lacking.
I filed a bug report, CMPLRLLVM-53005. I'll let you know its progress to a fix.
Steve_Lionel
Thanks, Barbara. My recollection is that the compiler is simply not allowing "specification inquiry" expressions in constant expressions. Specification Inquiry expressions are described in F2018 10.1.11p3, and 10.1.12 (Constant expressions) says the following is allowed:
(4) a specification inquiry where each designator or argument is
25 (a) a constant expression or
26 (b) a variable whose properties inquired about are not
27 (i) assumed,
28 (ii) deferred, or
29 (iii) defined by an expression that is not a constant expression,
Barbara_P_Intel
Thanks for the details, @Steve_Lionel. I added the info to the bug report.
DataScientist
fantastic! Thank you.
Igor_V_Intel
This bug is fixed in ifx 2025.0 compiler version.
