saving data files
diana_g_1
Hi, I'm writing a graphic program in fortran and I want a menu option that save me the informations of the figure that the user draw. Then I think to open a txt file and write into it informations. The program save by default the txt file in the same directory of the program, instead I want that the user can choose the directory where to save it. Is this possible? How can I do it?
Anthony_Richards
Is this a QuickWin program (you mention 'menu' item...).
When building a name for your textfile, you can always add a full path to the folder to which you want to save it.
If the folder doesn't exist, you can create one using MAKEDIRQQ. You can changedirectory using CHANGEDIRQQ.
Look up the Windows API function GETSAVEFILENAME for opening a SaveAs common dialog box which allows you to navigate to the folder of choice and create one if required, returning a full-path filename for the file you want to save data to..
andrew_4619
There is a Intel fortran sample showing how to use Windows API function GETSAVEFILENAME
SergeyKostrov
Valued Contributor II
>>...The program save by default the txt file in the same directory of the program, instead I want that the user can choose >>the directory where to save it. Is this possible?.. Yes and you need to initialize lpstrInitialDir member of OPENFILENAME structure passed to GetSaveFileName function.
diana_g_1
thank you very much to everyone!
