segfault in tokenize
Diehl__Martin
! Minimal reproducer for the ifx 2026.1 TOKENIZE intrinsic
program repro_tokenize_ifx
  implicit none
  character(len=:), dimension(:), allocatable :: t
  print*, 'version',__INTEL_COMPILER_BUILD_DATE
  call flush(6)
  call tokenize("aaa bbb ccc", " ", t)
  print*, size(t), len(t(1)), trim(t(2))
end program repro_tokenize_ifx
leads to
 version    20260617
forrtl: severe (408): fort: (8): Attempt to fetch from allocatable variable T when it is not allocated
Image              PC                Routine            Line        Source
repro_tokenize_if  0000000000405362  Unknown               Unknown  Unknown
repro_tokenize_if  000000000040527D  Unknown               Unknown  Unknown
libc.so.6          000006CF4402A1CA  Unknown               Unknown  Unknown
libc.so.6          000006CF4402A28B  __libc_start_main     Unknown  Unknown
repro_tokenize_if  0000000000405165  Unknown               Unknown  Unknown
when compiled with
ifx -fpp -check pointers repro_tokenize_ifx.f90
Diehl__Martin
here is the file
Arjen_Markus
FWIW the segfault does not occur with ifx 2025.3.2.
MarcGrodent
New Contributor III
I can reproduce this error with ifx 2026.1.1.
It occurs due to the compiler option (on Windows):
/check:pointers
Without this flag the code runs correctly.
So yes probably a compiler bug here.
