segfault with finalized dummy args
Ferdinand_T_
New Contributor II
Hello!
The following program seems to reveal a compiler problem with finalized optional, allocatable polymorphic, intent(out) dummy arguments in a subprogram, which let the executable exit with a segfault on procedure entry(?).
[fortran]
module m
    implicit none
    ! finalized derived type
    type :: derived_type
    contains
        final :: finalizer
    end type
contains
    ! derived type's final subroutine
    subroutine finalizer(this)
        type(derived_type), intent(inout) :: this
    end subroutine
end module
program p
    use m
    implicit none
    call do_something()    ! runtime segfault
    ! forrtl: severe (174): SIGSEGV, segmentation fault occurred
contains
    ! a subprogram which returns finalized derived type
    ! important: intent(out), allocatable, optional
    subroutine do_something(arg)
        type(derived_type), intent(out), allocatable, optional :: arg
    end subroutine
end program
[/fortran]
Note: As far as I checked it, the arguments attributes must not be changed (allocatable to pointer etc.) for the program to exhibit the reported behaviour.
Best regards
Ferdinand
Izaak_Beekman
New Contributor II
Which version of ifort are you using? How did you compile this?
Ferdinand_T_
New Contributor II
Recent ifort (unix) version 14.0.1, no compiler flags:
$ ifort test.f90
$ ./a.out
Image              PC                Routine            Line        Source
a.out              000000000046AEF9  Unknown               Unknown  Unknown
a.out              0000000000469870  Unknown               Unknown  Unknown
a.out              0000000000438E72  Unknown               Unknown  Unknown
a.out              000000000041F273  Unknown               Unknown  Unknown
a.out              00000000004041AB  Unknown               Unknown  Unknown
libpthread.so.0    00007F2C71C05CB0  Unknown               Unknown  Unknown
a.out              0000000000402CE4  Unknown               Unknown  Unknown
a.out              0000000000402C46  Unknown               Unknown  Unknown
libc.so.6          00007F2C7185776D  Unknown               Unknown  Unknown
a.out              0000000000402B19  Unknown               Unknown  Unknown
jimdempseyatthecove
Assuming allocatable, optional and intent(out) ...without pointer...
are permitted together, the error (SIGSEGV) is doubly interesting since the final routine should only be called upon deallocate (implicit or explicit). The deallocate code should not have been generated.
Jim Dempsey
