segmentation fault during execution
denaro
I am working on a bi-processor Xeon, 1Gb Ram, with Linux OS:
$ uname -a
Linux venere 2.6.3-4mdkenterprise #1 SMP Tue Mar 2 07:00:53 CET 2004 i686 unknown unknown GNU/Linux
and evaluating Intel Fortran Compiler:
$ ifort -V
Intel Fortran Compiler for 32-bit applications, Version 8.0 Build 20031016Z Package ID: l_fc_p_8.0.034
Copyright (C) 1985-2003 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
I have a scalar code and I tried to parallelize with the options:
-tpp7 -xN -axN -O2 -parallel -par_threshold100
but during the execution I get the SIGSEV segmentation fault, code error (174). The code without parallelization runs perfectly.
The code allocate 256MB of memory by using static matrix declaration. After some minutes of execution the run crashes. I found, by looking to the top command, that the during the execution the free RAM memory decreases until to become zero then the swap area starts to be used until it is free, eventually the code get segmentation fault.
Of course the scalar compiled code normally occupies only 256 Mb of Ram.
Does anyone know the reason of such a "memory eating"?
thanks, in advance
Filippo
I don't know if this will help, but you are running an old compiler. Please update to the current version, which I think is 8.0.049, and try again.
denaro
Thanks Steve,
do you know if I can download the latest version from the evaluation link?
Filippo
