segmentation fault
ananth_mg
when i tried to run program compiled using ifortv8.0,i'm getting segmentation fault.
It is first issuing this warning many times and then giving segmentation fault:
forrtl: warning (402): fort: (1): In call to QNEG3, an array temporary was created for argument #8
Part of the calling routine is:
! Allocate memory for temporary arrays
allocate ( arr3d(plon,plev,plat) )
do lat=1,plat
call qneg3('INIDAT ', lat, nlon(lat), plon, plev, 1, &
qmin(m), arr3d(:plon,:plev,lat))
end do
The called routine has:
subroutine qneg3 (subnam ,idx ,ncol ,ncold ,lver ,lconst , &
qmin ,q )
!Input arguments
character*(*), intent(in) :: subnam ! name of calling routine
integer, intent(in) :: idx ! chunk/latitude index
integer, intent(in) :: ncol ! number of atmospheric columns
integer, intent(in) :: ncold ! declared number of atmospheric columns
integer, intent(in) :: lver ! number of vertical levels in column
integer, intent(in) :: lconst ! number of constituents
real(r8), intent(in) :: qmin(lconst) ! Global minimum constituent concentration
! Input/Output arguments
real(r8), intent(inout) :: q(ncold,lver,lconst) ! moisture/tracer field
What's the declaration of qmin?
You probably need to raise your stack limit.
ananth_mg
I've increased stacksize using ulimit.I'm not doing any optimizations also.Options I've given are:
-i4 -r8 -align -g -C -fpstkchk -fp -save -check all.Environment variables are all properly set.
Declaration of qmin is in qneg3.F90 file as:
as I said in previous thread.
Any help is appreciated.
florinm1982
make sure you don't deallocate temporary arrays and after that try to use them... If you do so you would probably obtain the same type of error you report.
Florin M.
