segments intersection
cacciatore
Hi
I need a fortran algorithm to check if two line segments intersect each other ( the segments being defined by their cartesian coordinates).
Can anyone help me?
Geraldo Cacciatore
llynisa
The problem is trivial in two dimensions - just check if the lines are parallel or not. How many dimensions do you want to work in?
cacciatore
llynisa thanks for answering.
I know how to solve the problem using analytical geometry: find the interception point of the supporting lines (if the segments are not parallel) end see if this point is inside both segments ( my space is 2D). Check also for overlapping, etc..
But I am not an expert fortran programmer, and as my fortran implementation may not be an efficient one I am looking for something already tested.
Thanks again
Geraldo
Intel_C_Intel
Here is some code that caluslates the intersection of two lines.
Hope this helps.
David.
SUBROUTINE CROSS (x1,y1,x2,y2,p1,q1,p2,q2,E1,N1,kout)
!       CHECK FOR INTERSECTION OF LINE x1,y1-x2,y2 WITH p1,q1-p2,q2, result in E1,N1
        integer*2	kout	! 0=no solution, 1=solution
		INTEGER*4 x1,y1,x2,y2,p1,q1,p2,q2,E1,N1,EMINA,NMINA,EMAXA,NMAXA,EMINB,NMINB,EMAXB,NMAXB
        real*8    EA,EB,EC,NA,NB,NC,COTA,COTB,D
        kout=0
        IF (x1EMAXB.OR.NMINA>NMAXB) GO TO 500
        IF (EMINB>EMAXA.OR.NMINB>NMAXA) GO TO 500
        EA=x1
        NA=y1
        EB=p1
        NB=q1
        IF (p1==p2) EB=EB+1D-3
        IF (x1==x2) EA=EA+1D-3
        COTA=(NA-y2)/(EA-x2)
        COTB=(NB-q2)/(EB-p2)
        IF (DABS(DABS(COTA)-DABS(COTB)).LT.1D-10) GO TO 500
        EC=(EA*COTA-EB*COTB-NA+NB)/(COTA-COTB)
        D=EC
        NC=EC*COTA-EA*COTA+NA+5D-1
        EC=D+5D-1
        E1=EC
        N1=NC
        IF (E1EMAXA.OR.E1>EMAXB) GO TO 100
        IF (N1NMAXA.OR.N1>NMAXB) GO TO 100
		kout=1			! valid solution
        GO TO 500
  100   kout=0
  500   RETURN
        END
cacciatore
Thanks,I will try the code you send me.
I found an interesting algorithm in www.brunel.ac.uk/~castjjg/java/crossed/crossed.html that also deserves a try.
Best regards
Geraldo Cacciatore
