setting a fortran variable to NaN
Scott_L_
There is the isnan function to test a variable for a NaN value, but is there a function I can use to set a variable to NaN? I am using ifort 17.1 on windows x64 and Linux. It would be preferable to not have to alter the /fpe options to let sqrt(-1) slide but if that's the best option, which fpe value would be safest on Linux and windows visual studio? thanks scott
Arjen_Markus
You can do so with the function ieee_value(). Here is a small demo program:
program setnan
    use, intrinsic :: ieee_arithmetic
    implicit none
    real :: x
    x = ieee_value( x, ieee_signaling_nan )
    write(*,*) x
    x = ieee_value( x, ieee_quiet_nan )
    write(*,*) x
end program setnan
Arjen_Markus
program setnan
    implicit none
    real :: x
    write(*,*) x
    write(*,*) x
end program setnan
Scott_L_
Andrew_Smith
Valued Contributor I
Is it possible to set a parameter to nan? Calling ieee_value as part of a parameter definition doesn't work:
real(DP), parameter :: aNan = ieee_value(aNan, ieee_signaling_nan)
error #6259: This array or function or substring is invalid in constant expressions. [IEEE_VALUE]
Steve_Lionel
IEEE_VALUE is not permitted in a constant expression, per the standard. I polled a couple of the committee members about this, and it was felt it had limited usefulness. You can use a hex literal if you want, or use run-time initialization.
jimdempseyatthecove
The usefulness of having a parameter as a signaling is rather limited.
The use on rhs of = .OR. in IF(var == aNAN) should cause a trap...
... however, if the Fortran compiler generates a integer binary compare, then you will not trap...
however, if binary (integer) compare is performed, then it will detect one of 2^22 or 2^51possible SNAN's.
NaN - Not a Number
It's possible to represent values that aren't real numbers, such as 0 / 0, in the IEEE floating-point format. A value of this kind is called a NaN. A NaN is represented by an exponent of all ones and a non-zero significand. There are two kinds of NaNs, quiet NaNs, or QNaNs, and signaling NaNs, or SNaNs. Quiet NaNs have a leading one in the significand, and get propagated through an expression. They represent an indeterminate value, such as the result of dividing by infinity, or multiplying an infinity by zero. Signaling NaNs have a leading zero in the significand. They're used for operations that aren't valid, to signal a floating-point hardware exception.
Jim Dempsey
Andrew_Smith
I use a nan parameter for debugging. I initialize components of derived types to nan so that I can tell if it gets used before initialisation.
JohnNichols
Another way is to initialize to a strange number that you will never use or is unlikely to occur, initialize at creation to that and then test for it, before you use it.  You are just looking for a change are you not.
JohnNichols
There will be the strangely interesting numbers potentially in it anyway, may as well make your own strange so you know you did it.
