29425 Discussions
setting optimisation to 3 causes program to hang
jim_cox
My program is hanging if i set optimisation to /O3
It is a nested loop
First pass through the outer loop, the inner loop is all good
But on second pass through the outer, the inner loop hangs
Any thoughts what might cause this?
It works fine with /02
I note that one difference with /O3 is that a number of variables, including one of the loop control variables, are shown as a 'register variables' - maybe thats a hint
Thankx again for your help
Jim
=mjc=
What do you mean "hang"? Does the process go CPU-bound? Does it just stall at 0% CPU usage? Can you provide a test case?
IDZ_A_Intel
Also,
Is the program multi-threaded, autoparallized, or single threaded?
And, is the loop performing a convergence? If convergence, show us how you test for convergence.
Jim Dempsey
jim_cox
(problem with lost post - lets try this again...)
hung means hung like sitting in an infinite loop making no progress - loop counter display never goes past one on the scond iteration
taskman shows 13% cpu usage on both first and second iterations
Sorry I cant easily provide a good testcase as its one of my old monster programs :(
Its linked multi threaded
And its not parallelised yet - thats where I'm trying to go
Working build uses...
/nologo /Od /fpp /assume:nocc_omp /gen-interfaces /f77rtl /intconstant /fpscomp:ioformat /fpscomp:general /warn:interfaces /integer_size:16 /Qzero /fpe:1 /Qftz /names:uppercase /iface:cvf /module:"Release\" /object:"Release\" /traceback /libs:static /threads /4Yportlib /c
I'm think it may be to do with variable declartions : seems like something there first time is munged second time round
Any hints where to go looking or on sucessful optimsation welcomed
IDZ_A_Intel
Have you checked you code for use of uninitialized variables? Your program cannot assume a variable not used is auto-initialized to 0. Testing with run-time option to check for use of uninitialized variables will catch most offences.
Jim Dempsey
jim_cox
Thanky Mr Dempsey - I think that answers my question.
Found a couple of examples
And I now have a build with /O3 that runs
Program run times are now a 1/4 of previous - yay :)
But when I try turning on /QParallel I get
4>(0): internal error: backend signals
4>Link: error #10014: problem during multi-file optimization compilation (code 4)
messages
Any thoughts? What am I missing?...
A very happy Friday to all
Jim
=mjc=
IDZ_A_Intel
Try turning OFF Interproceedural Optimizations.
IPO may be a seperate issue.
jim_cox
That worked to get it to link
But now I'm back to it hanging on the second pass through the loop :(
Jim,
Can you provide us with the source that results in the internal error with /Qparallel? Include any INCLUDE or MODULE files it needs. Thanks.
