several outputs on the same line
haminin
Hi there
Could someone let me know how to write several times free-format outputs on the same line.
Many thanks
Hamid
Les_Neilson
Valued Contributor II
Quoting - Peter
do i=1,12
write(3,*) (a(i),char(9), j=1,11)
end do
Now I'm confused. :-)
What you have written is as follows
i=1
write out a(1) followed by a TAB, 11 times on the same line.
i=2
write out a(2) followed by a TAB, 11 times on the same line
and so on.
Do you really want the same number repeated 11 times along the same line ?
Note: Something I wanted to mention in my earlier reply but forgot.You could also replace char(9) with ',' to make the file a "comma separated value" file. This would have the advantage of making the separating character visible in a editor and/or printout of the file.
I am assuming that your real world problem is more complicated. Have you considered the possiblity of using an "internal write" to build a format string and then using that format for your write-to-file?
Les
haminin
Quoting - Peter
Let me know if this works for you!
Posts 19 and 20 both work.
As Steve and David say, RECL needs change.
Many thanks
Hamid
haminin
It is just an example and as you said the real problem is something else.
I need to read about that. If it is easy to explain, please kindly do that in an example.
Many thanks
Hamid
Les_Neilson
Quoting - haminin
Many thanks
Hamid
"As Steve and David say, RECL needs change."
I tried to hint at that in my first reply, alas my "hinting skills" need improving :-)
For internal I/O the process is along the following lines:
! declare a character string variable which will be used to hold the format
! ( note if the actual format to be used is more detailed than the one shown here
! it needs to be long enough to hold it)
character(80) :: my_fmt
! a character variable containing the separator
character :: csv
! an integer variable specifying how many numbers to write
integer :: n
! an integer variable specifying the calculated record length
integer :: recl
! loop counter
integer :: i
! Error status
integer :: ierr
! the array of data - size to be determined at run time
real, allocatable :: a(:)
! Initialise the separator
csv = ',' ! or could be char(9) for example
! Do something to get the number of values "n"
n = 42
! Using "n" allocate the array to receive the data
allocate(a(n), stat=ierr)
! Do something to read in the "n" values into array "a"
do i = 1,n
a(i) = i
enddo
! This is the internal i/o part
! Basically the "file unit" we write to is our character string "my_fmt"
! your actual format will depend on what you want to write
write(my_fmt, "(a1,i3,a16)") "(", n-1, "( f6.3, a),f6.3)"
! This will buildthestring my_fmt = "(41(f6.3,a),f6.3)"
! We will write out n-1 values and csv's followed by the final value
! calculate the record length
recl = (n-1)*7 + 6
open(3,file="out.txt",status="unknown",RECL=recl)
! Write to the file using our constructed format string
write(3,my_fmt) ((a(i),csv),i=1,n-1), a(n)
HTH
Les
haminin
Quoting - Les Neilson
Les
Appreciated very much. It can be very helpful in the next step of my project.
Hamid
Peter
i=1
i=2
and so on.
Les
Les,
In Hamid's first code he wants to print same number repeatedly along the same line. I was just trying to modify that code.
