severe (174): SIGSEGV - libc.so.6
nansal
I am using the intel fortran compiler for Linux 10.1.015 and intel MKL 10.0.2. When I run my executable program (TESTKMAT)with small dimension of matrices, I have NO ERROR. But when I increase dimension of matrices, I have this message after running the executable program:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
TESTKMAT 0804B554 Unknown Unknown Unknown
TESTKMAT 0804AD91 Unknown Unknown Unknown
libc.so.6 0071E390 Unknown Unknown Unknown
TESTKMAT 0804ACA1 Unknown Unknown Unknown
I tried to increase the stack size in terminal:
$ source /opt/intel/fc/10.1.015/bin/ifortvars.sh
$ source /opt/intel/mkl/10.0.2.018/tools/environment/mklvars32.sh
$ ulimit -s unlimited
and using the compiler option '-heap-arrays' such as bellow:
$ ifort -heap-arrays TESTKMAT.for -L LD_LIBRARY_PATH -I LD_INCLUDE_PATH -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_lapack -lmkl_ia32 -lmkl_core -lguide -lpthread
But I did not have any improvement and the previous message there was.
I really appreciate your helps.
Ron_Green
compile and link with -g -traceback -fp-stack-check -fpe0 -check all
this may help isolate the problem.
ron
nansal
ron
Thank you so much Ron,
I used those compiler options.
My problem was in a line that I had assigned a real value to an array which has only 3 elements {I have defined it by 'DIMENSION A(3)'}!
In my program, the array of "A" is always fixed and has only 3 elements. But corresponding to the number of atoms, other matrices can have large sizes. When the number of atoms is 3718 I have no problem but when I set my program to 4950 atoms, this problem occurs. However, the array of "A" is unchanged.
Really I don't know what have happened?
Thanks in advance!
joey_hylton
Quoting - nansal
Thanks in advance!
Did you get any solutions?
I met the same problem, but I located it to MPI functions which has no problem with the data size.
J.L
Ron_Green
Quoting - nansal
Thanks in advance!
There are a few other diagnostics to try:
-g -traceback -fp-stack-check -gen-interfaces -warn interfaces
There is a bug in -gen-interfaces -warn interfaces with the 11.0.083 compiler, so if you have 11.0.081 or older use that compiler.
ron
Ron_Green
Quoting - joey_hylton
J.L
When a call to an MPI routine seg faults, I look very carefully at the arguments. Make sure you are passing variables that have the correct MPI data types. Another source could be if the drivers for your underlying fabric (myrinet, infiniband) are not up to date or you have a mismatch of your adapter firmware to your dapl drivers. If you are using a non-ethernet interconnect, check all your adapters for the correct (and matching) firmware versions, and check that your drivers are up to date AND are supported on your OS. Sometimes people go crazy installing the latest version of their Linux distro and forget that the drivers they use for the fabric are not supported on these newest versions of the distro.
ron
