29653 Discussions
severe error (157) using insertmenuqq
lcorona
The project consist of two menus, the first one where you enter data (main menu), it is defined on initialsettings, and the other appears after all the data has been processed (design menu). The user has the option move from one menu to the other. But after changing menus, at the fourth try it gives the error:
forrtl: severe (157): Program Exception - access violation
This is the line that is causing the error on the design menu file:
retlog=insertmenuqq(8,0,$menuenabled,"Losa"C,sub_losa)
What can it be?
