29386 Discussions
simple instructions for linking to mkl_lapack on Mac OS 10.6?
bpabbott
I'm a new user of ifort and MKL.
I have a fairly large fortran project which includes both f77 and f90+ sources, and is build using a makefile. I'd like to replace Apple's vecLib with MKL.
My build terminates with ..
ifort -o ha_sdafemsda_v1 ha_sdafemsda_v1.o phiq_sdafemsda_v1.o sdafemsda_v1.o sub1_sdafemsda_v1.o cmatr.o cmatr_iso.o fmin_baw.o sub2.o vlim.o epsc_multilay_isomatr.o epsc_multilay_obl.o bpa_getargfromfile.o octave_matfile.o ha_sdafemsda_v1_cmd.o -shared-intel -L"/opt/intel/Compiler/11.1/067/Frameworks/mkl" -lmkl_lapack -lguide -lpthread
ipo: warning #11011: unable to find -lmkl_lapack
ipo: warning #11020: unresolved _zgeev_
It wouldn't surprize me to find I'm doing several things wrong. If one does not exist, can someone give me a brief set of instructions for how to build a simple fortran program that calls lapack?
TimP
An important part of that would be to consult the link advisor in the right hand column of the forum header page. You appear to have copied some link options from a linux combinations of ifort and MKL of several years ago.
bpabbott
Quoting - tim18
I went to the link-line advisor at
and obtained the link options below.
-L$(MKLPATH) $(MKLPATH)/libmkl_solver_sequential.a -lmkl_intel -lmkl_sequential -lmkl_core -lpthread
My MKLROOT and MLKPATH are set as
MKLROOT = /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl
MKLPATH = $(MKLROOT)/lib/32
Now I see
ifort -o ha_sdafemsda_v1 ha_sdafemsda_v1.o phiq_sdafemsda_v1.o sdafemsda_v1.o sub1_sdafemsda_v1.o cmatr.o cmatr_iso.o fmin_baw.o sub2.o vlim.o epsc_multilay_isomatr.o epsc_multilay_obl.o bpa_getargfromfile.o octave_matfile.o ha_sdafemsda_v1_cmd.o -L/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32 /opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_solver_sequential.a -lmkl_intel -lmkl_sequential -lmkl_core -lpthread
ipo: warning #11009: file format not recognized for /opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_intel.dylib
ipo: warning #11009: file format not recognized for /opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_sequential.dylib
ipo: warning #11009: file format not recognized for /opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_core.dylib
TimP
Have you mixed 64-bit build and 32-bit libraries? The environment paths and -L should be set automatically when you have your compiler environment set, since you are using the MKL which comes with the compiler.
bpabbott
Quoting - tim18
Your hypothesis makes sense to me. How might I modify what I'm doing to confirm?
TimP
You would simply set up the environment variables by sourceing the ifortvars compiler script. Then, you would leave out the -L specification, as the correct MKL library folder should be on the search path already.
By the way, a -L specification ends with a directory name, doesn't include any specific library. It would not work to search a library for itself or other libraries, which is what you specified.
bpabbott
Quoting - tim18
Are you sure my "-L" option is wrong?
-L/Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32
I tried running ifortvars ...
/opt/intel/Compiler/11.1/067/bin/ifortvars.sh ia32
... but my build still fails.
ifort -o ha_sdafemsda_v1 ha_sdafemsda_v1.o phiq_sdafemsda_v1.o sdafemsda_v1.o sub1_sdafemsda_v1.o cmatr.o cmatr_iso.o fmin_baw.o sub2.o vlim.o epsc_multilay_isomatr.o epsc_multilay_obl.o bpa_getargfromfile.o octave_matfile.o ha_sdafemsda_v1_cmd.o -L/Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32 /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_solver_sequential.a -lmkl_intel -lmkl_sequential -lmkl_core -lpthread
ipo: warning #11009: file format not recognized for /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_intel.dylib
ipo: warning #11009: file format not recognized for /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_sequential.dylib
ipo: warning #11009: file format not recognized for /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_core.dylib
When I remove the "-L" option the MKL libraries are not found.
ifort -o ha_sdafemsda_v1 ha_sdafemsda_v1.o phiq_sdafemsda_v1.o sdafemsda_v1.o sub1_sdafemsda_v1.o cmatr.o cmatr_iso.o fmin_baw.o sub2.o vlim.o epsc_multilay_isomatr.o epsc_multilay_obl.o bpa_getargfromfile.o octave_matfile.o ha_sdafemsda_v1_cmd.o /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/32/libmkl_solver_sequential.a -lmkl_intel -lmkl_sequential -lmkl_core -lpthread
ipo: warning #11011: unable to find -lmkl_intel
ipo: warning #11011: unable to find -lmkl_sequential
ipo: warning #11011: unable to find -lmkl_core
Is there some way I can confirm the ifortvars script is functioning for correctly?
bpabbott
It just occurred to me that I needed to source ifortvars.sh
source /opt/intel/Compiler/11.1/067/bin/ifortvars.sh ia32
After doing that, my program compiled and ran witiout problem ... both with and without the "-L" option.
Out of curiousity I did some speed comparisons. Using ifort and mkl_lapack, my program ran in 1.85 secs as compared to ifort with veclib which ran in 2.31 secs. Using gfortran with veclib resulted in an execution time of 2.86 secs.
