29390 Discussions
size of allocatables in derived types
Lars_Jakobsen
I have a question conserning the use of allocatables in derived types.
I have made this test case:
[fortran]program Dynamic_memory
  implicit none
  !-- Type1
  type :: T_myType1
    integer, dimension(:), allocatable :: myIntAll
  end type
  type(T_myType1)                        :: myType1_1 !  1 pointer member
  type(T_myType1), dimension(10)         :: myType1_2 ! 10 pointer members
!-- Type2
  type :: T_myType2
    integer, dimension(1)  :: myIntAll
  end type
  type(T_myType2), dimension(10)  :: myType2_2
  integer         :: mem
  integer, dimension(:), allocatable :: myAlloc
!-- body
  write(*,*) 'Welcome to Dynamic_memory 101'
  mem = sizeof(myType1_1)
  write(*,*) 'The sizeof myType1_1 is currently: ', mem
  mem = sizeof(myType1_2)
  write(*,*) 'The sizeof myType1_2 is currently: ', mem
  mem = sizeof(myType2_2)
  write(*,*) 'The sizeof myType2_2 is currently: ', mem
  read(*,*)
  end program[/fortran]
 The output of this is:
 The sizeof myType1_1 is currently:           36
 The sizeof myType1_2 is currently:          360
 The sizeof myType2_2 is currently:           40
Hence myType1_1 uses 36 bytes of memory without having allocated any room for myIntAll whereas myType2_2 only uses 40 bytes corresponding to the size of the 10 integers that I have made room for (I am using integer = integer(4)).
My originally thought was that I could save some memory by making the array myIntAll allocatable, however there seem to be some overhead involved in using allocatables in derived types that are not present with fixed size arrays. Is it possible to calculate this overhead or am I doing something wrong here?
Lars
When you have deferred-shape arrays in a derived type, whether they are POINTER or ALLOCATABLE, what gets put in the derived type is the descriptor for the array.  This is of variable size depending on the number of dimensions.  An array of these would have an array of descriptors. Typically you would use allocatable arrays here when you don't know in advance the size of the arrays you need.  If you do know, then by all means make them fixed-size.
Lars_Jakobsen
Thank you Steve.
In my case the array that I would put into the derived type would sometimes have size 2 and other times size 4 and in rare instances size 9. If I have to declare them as fixed-size I would have to declare them all as size 9 even though I only rarely need 9 entries.
The size of the descriptor according to the help file is (on IA-32) (6+3*x)*4 bytes, where x is the dimension of the array in the above example this equal 36 bytes.
But if the descriptor uses 36 bytes of memory, then there is no benefit in using deferred-shape arrays.
Lars
Certainly no benefit for fixed-size arrays where the maximum size is 40 bytes or less.
