snan initialization for allocatable arrays
abhimodak
Hi
Some time after this (https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/532202) , IVF started to do NaN initial-value setting for allocatable arrays.
The snippet below shows that allocatable arrays from type are not getting initialized. Is there anyway to do that?
The compile-line is: ifort /Od /debug:full /Qinit:snan /Qinit:arrays Test.f90
I am using Compiler 17.0 Update 4 with Visual Studio 2015.
Abhi
      Module OM
         Implicit None
         Type newOBJ
            Integer :: j
            Real(8), Allocatable :: B(:)
         End Type newOBJ
      Contains
         Subroutine SetObject(This)
            Type(newOBJ), Intent(OUT) :: This
            Allocate(This%B(2)) ! This won't initialize to NaN
         End Subroutine
      End Module OM
      Program Test
         Use OM
         Implicit None
         Real(8), Allocatable :: A(:)
         Type(newOBJ) :: OBJ
         Allocate(A(3)) ! gets initialized to NaN
         !Allocate(OBJ%B(2)) ! OBJ%B will get initialized to NaN
         Call SetObject(OBJ)
      End Program Test
Lorri_M_Intel
You've discovered a bug that still exists in the current release.
Please submit a bug report, which you can do by using the big orange button on the top of the main page of this forum.
To answer your question, you could create a variant of SetObject that accepts the component, and does the allocation.   For example:
         Subroutine SetObject2(This)
            real(8), allocatable :: This(:)
            Allocate(This(2)) ! This did initialize to NaN
         End Subroutine
I did not try that with the 17.0 compiler, but it did work with our latest sources.
                          --Lorri
