sort the array
yingwu
I need to sort a 1-dimensional real-type array. I find I can use sortqq and qsort. Is there any difference?
By the way, could I ask what is integer(2)???? What the '(2)' is for?
Thanks very much.
jimdempseyatthecove
How large is the array?
Are multiple cores available?
Is the output array the input array? (or seperate arrays)
integer(2) means 2-byte integer (16-bits). In C this would be a short (short int)
Jim
yingwu
Jim
the array has 10000 elements. Yes, 4 CPUs. A seperate array is expected.
jimdempseyatthecove
For 10,000 reals, SORTQQ may be faster than QSORT (experiment).
However, QSORT has the advantage of being able to check for NaN's and/or denormalized nubmers.
The disadvantage of both is they sort in place (as opposed to takingin and out arrays).
If this sort occures very often, then it might be worth the effort to write a specialized sort (SSE using multiple threads). 10,000 is probably not large enough to involve multiple threads, but involving SSE may help.
Jim
