sortqq problem
Axel_P_
Can anyone explain why the following program does not work? All but the first element of array lar2 are truncated to the lower 32 bit by sortqq. That's independent of compiler version and the inclusion of a "use ifport" statement.
      use ifport
      implicit none
      integer*4 i,mod,iflag,size
c      integer*4 irand
      integer*4 iaux
      integer*8 lar2(15),count,adrarray
      iflag=1374
      i=mod(irand(iflag),15)+1
      iflag=0
      do i=1,15
        iaux=mod(irand(iflag),15)+1
        lar2(i)=iaux*2_8**32+i
        write (*,*)  lar2(i)
      end do
      adrarray=loc(lar2)
      count=15
c      size=Z'00060000'
      size=SRT$INTEGER8
      write (*,*) adrarray,count,size
      CALL SORTQQ (adrarray,count,size)
      write (*,*) 'After sort:'
      do i=1,15
        write(*,*) lar2(i)
      end do
      stop
      end
> ifort sortqqbug.f
> ./a.out
           21474836481
           12884901890
           38654705667
           30064771076
           34359738373
           47244640262
           17179869191
           12884901896
           12884901897
           17179869194
           25769803787
           25769803788
           34359738381
           30064771086
           25769803791
               6925152                    15      393216
               6925152                    15      393216
 After sort:
                     2
                     5
                     6
                     7
                     8
                     9
                    10
                    11
                    12
                    15
           21474836481
                     4
                    13
                    14
                     3
There's a bug in SORTQQ for INTEGER*8. I can see it in the code. I will report it to the developers and get it fixed. Thanks for bringing this to our attention. Issue ID is DPD200256464.
