29650 Discussions
spawning system command from fortran
chuck_taylor
Hi There,
I'm porting some fortran from openVMS to XP and am using the compaq VF environment, and need to issue a system command. On VMS I'd do something like:
call lib$spawn('dir/out=arf.arf')
How can I accomplish this with my XP application?
thank you,
-Chuck Taylor
TimP
CALL SYSTEM() allows you to submit a command to the operating system. That command might start a script, which could specify its own shell in order to avoid confusion between shells. This is an extension supported in a similar way by most vendors' Fortrans.
