29362 Discussions
specifying libraries when linking with ifort for Windows
connell
In the Linux versions of Ifort you can specify libraries by using the following syntax
-L$path -lname1 -lname2
i.e -L specifies the directory to search and l the libs in that directory. Is there any wayof doing something similar with the windows versions?
You can, but it's a bit more complicated. The compiler itself doesn't have a switch for this but the linker does. So you would write:
ifort foo.obj /link /libpath:pathtolibs lib1.lib lib2.lib
The /link tells ifort that everything that follows is for the linker.
You can also add the library path to the definition of the LIB environment variable which will accomplish the same thing.
